@losawing@iampete Several copter tailsitter commits went into master yesterday, so I rebased and rebuilt the flight-test-3 binaries. There should be no changes in functionality from the previous version.
The only additions to flight-test-3 are now the gain scaling (interpolation and attitude/throttle) and the removal of thrust limiting in AP_MotorsMatrixTS.
angle boost =0 is my default value for this parameter. This is something I kept constant from the beginning as it was an advise from tridge early in this thread.
My last flying wing made for speed. 95cm wing span, about 25dm² and 1kg with 4s battery. No vectored thrust. I will begin with CG at 20% of mean cord. Airfoil is TP100,7.2% relative thickness, designed to have a constant Cm over a wide Cl range.
4 motors 2600KV: 1808 size for top and bottom, 2208 size for wings. 5152 gemfan propellers for tuning and then I plan to test emax 5075 propellers. The pixhawk will run the copter tailsitter code. First test expected soon.
yes, top and bottom motors react very fast. Stability seems to be very good. Maybe tomorrow I will test transitions. The thrust delivered by the four motors is incredible, this plane is going to be ballistic.
Around 58m/s maximum speed with throttle limited at 75% and 5 inches pitch propellers. Acceleration is amazing, up to 20m/s². The wing can go faster but I have to ensure first the RTL function is working because it becomes very small quickly.
I have about 10 flights, transitions and fixed wing flight are very good. The most difficult is to tune the pitch axis to get a neutral and smooth behavior at low and high speed.
Thatâs very fast! Glad to hear the transitions worked.
Looks like the airspeed sensor is working well at high speeds; should be good for the interpolation speed scaling option in q modes.
thank you for all these encouragements and thanks to the developers. @lorbass I agree the light blue is not the best choice but I have a solar roll almost 30 years old that I want to finish. I have now only 1 meter left so this is done @iampete, I tried this evening q_assist and had a surprise. When assist speed is reached the wing make a sudden transition to a mode that look like to q_stabilize. The forward transition was almost impossible as the speed was not high enough. I begun with assist speed =13 and the forward transition failed then I reduced the assist speed to 10 but the problem remains. I fly with the binaries from post 1706. I tested q_assit 1 or 2 months ago and it was perfect as it allowed to fly at high alpha safely with plane modes.
@losawing The new binaries should behave the same as what you are flying (including the qassist issue you reported), but it would be nice if youâd be willing to test with those, so that we are closer to whatâs in master.
I forgot to mention that there are some parameter changes in this PR to make them (hopefully) less confusing.
There is now a bitmask to enable one or more of 3 options (default is 1=boost-only):
// @Param: TAILSIT_GSCMSK
// @DisplayName: Tailsitter gain scaling mask
// @Description: Bitmask of gain scaling methods to be applied: BOOST: boost gain at low throttle, ATT_THR: reduce gain at high throttle/tilt, INTERP: interpolate between fixed-wing and copter controls
// @User: Standard
// @Bitmask: 1:BOOST,2:ATT_THR,4:INTERP
and a separate parameter for the throttle/tilt based maximum attenuation (min scale value):
// @Param: TAILSIT_GSCMIN
// @DisplayName: Minimum gain scaling based on throttle and attitude
// @Description: Minimum gain scaling at high throttle/tilt angle
// @Range: 0.1 1
The max gain boost at low throttle now defaults to 2, and has no effect on the other 2 options:
// @Param: TAILSIT_THSCMX
// @DisplayName: Maximum gain boost
// @Description: Maximum gain boost at low throttle
// @Range: 0.1 5
TAILSIT_SPDMIN/MAX function as before, but only affect the gain interpolation option
TAILSIT_GSCMSK=3 would be low throttle boost plus attitude/throttle based attenuation
TAILSIT_GSCMSK=5 would be low throttle boost plus gain interpolation
Fix not tested, but can only affect the elevator boost when bit 0 of TAILSIT_GSCMSK is set.
Also, Iâd recommend not using BOOST for a copter tailsitter anyway, so TAILSIT_GSCMSK = 2 for ATT_THR or TAILSIT_GSCMSK = 4 for gain INTERPolation would be my recommended test cases.
first failed forward transition to fbwa with q_assist_speed=13 at 288s. Switched back to q_hover at 292s and landing. I changed q_assist_speed from 13 to 10m/s and made another fight: Successful transition at 454s and q_assist triggered by airspeed at 628s.
This is a log of my jet wing, there are also manual and acro modes.
