I have Dual gps on board and both working normally.in mission planner incan able to see both gps status showing 3dgps.
When looking at QGCS run by SIYI Mk15 unit it shows only one gps status and how should i enable second gps status to display.
Battery showing as percentage in main screen,if i want to display as a voltage what parameter i hava to change?
Simply put: You can’t
I’m having the same issues.
The workaround I’ve been using to have HDOP for second GPS and battery voltage is the display on the bottom can be changed to display those values.
I have created widgets for the second gps status but i couldn’t find vehicle parameter for the battery voltage.
I have other doubts in QGCS.
1.if my mission has 10 waypoints.if i interrupt the mission inbetween for example waypoint number 5 changed to guided mode.
If i want to resume the mission from waypoint no 5 ,how can i do that…
Mission planner has this function like i have to click no 5 waypoint and change mode to auto.
2.my gimbal control connected to flight controller via serial protocol ( A8 mini ).
Mission planner has the function like point payload here or point payload to user geo co-ordinates.
Gimbal will automatically turn that coordinate point…
Here is what I’ve got:
(Currently no values showing as not connected to drone)
In regards to other issues can’t really help you as I operate differently - I use Auto mode and then change to a different flight mode using the flightmode switch on my RC. When I’m done with what I want to do I change back to Auto and the mission continuous. In that way don’t rely on a connection to the Ground-station.
