Hi, I’m using two ms4525do with pixhawk4 (i2cA and I2cB). If i connect both sensor i get airspeed value only from the second sensor. The only way to get value from the first sensor is connect only it with pixhawk and reboot.
I’ve used theses parameters:
ARSPD_AUTOCAL=0
ARSPD_BUS=1
ARSPD_FBW_MAX=22
ARSPD_FBW_MIN=9
ARSPD_OFFSET=186,7726
ARSPD_OPTIONS=0
|ARSPD_PIN=65
|ARSPD_PRIMARY=0
ARSPD_PSI_RANGE1
ARSPD_RATIO2
ARSPD_SKIP_CAL0
ARSPD_TUBE_ORDER=2
ARSPD_TYPE=1
ARSPD_USE=1
ARSPD2_AUTOCAL=0
ARSPD_OFFSET=186,3123
ARSPD2_BUS=2
ARSPD2_PIN=65
ARSPD2_PSI_RANGE=1
ARSPD2_RATIO=2
ARSPD2_SKIP_CAL=0
ARSPD2_TUBE_ORDR=2
ARSPD2_TYPE=1
ARSPD2_USE=1
