Can anyone tell me how to run dronekit sitl with version 3.5 of copter. I can only find version 3.3 when I do dronekit-sitl download.
Thanks so much!
Thanks so much!
Sorry, no precompiled binaries are available for 3.5
When using dronekit-sitl with my own binaries I tend to supply the path=
named parameter to dronekit-sitl’s constructor.
This does require compiling your own ardupilot binary, of course.
Thanks for the quick answer?.
Any specific reason for that?
I just don’t want to learn how to build it if I do not have to.
Best
Lack of time and knowledge would be a start to it
Sorry. But it is good for you (just ask your surgeon-general).
Note that the binary in question here is our bog-standard SITL binary. So
you’d use something like:
AP_BINARY="$HOME/rc/ardupilot/build/sitl-debug/bin/arducopter"
python example.pl --path="$AP_BINARY" …
Peter
Peter - thank you so much. Are there instruction on how to build copter 3.5 on Windows?
Step 1: Install Linux.
OK, so that’s just the way my instructions would start Maybe try this
link instead:
http://ardupilot.org/dev/docs/building-ardupilot-onwindows10.html
Yours,
Thanks Peter,
Sorry for the nag. I am simply using machines that do not allow the changes that are required in Windows to build for security reasons. Since I am in a secure environment there are many limitations.
Can I build it on one machine and use it in others or do I need to build it on the same machine I use it on?
Can I copy it from someone who already has built it?
I need it because there seem to be many bugs in the available 3.3.
Ben
Heh. Careful with your wording. “secured” environment, perhaps.
“secure” is almost certainly not the case
So long as the machines are close in configuration you should be able to
copy with binary around.
Again, so long as the binaries are close.
The software has vastly increased in capability since 3.3 too.
ATM we don’t create SITL binaries for firmware.ardupilot.org. Making x86
SITL binaries available for Linux available on firmware.ardupilot.org
would actually be pretty straight forward. Windows binaries -
not-so-much.
Perhaps you could consider using an AWS instance to create your binaries
on?
Ben
Yours,
Hey Peter,
Continuing the saga…
I took your advice on trying to build sitl on an AWS ubuntu server.
In spite of running Tools/scripts/install-prereqs-ubuntu.sh -y (successfully - I think)
I get:
/bin/sh: 1: arm-none-eabi-gcc: not found
When I do the make.
I need to do it for Px4-v2 right?
In any case I am trying to figure out why the arm compiler is not available.
Ben
Update - Success I think. I manually installed the arm compiler.
So now I have a file called: ArduCopter-v2.px4
Can you help me running it from a line command or from a python sitl call?
The px4-v2 is for pixhawk not for simultation.
to build for SITL you need to use
./waf configure
./waf copter
And it should build SITL.
When I do the make.
Yes, indeed. However, SITL requires binaries compiled for the platform
you’re working on, not an embedded platform!
See @khancyr’s note
You could actually just start the autotest on the AWS server:
./Tools/autotest/autotest.py --debug build.ArduCopter fly.ArduCopter
(you can add --map to that if you happen to have remote X working)
Or the sim_vehicle.py interface to SITL:
./Tools/autotest/sim_vehicle.py --debug -v ArduCopter
Both of those will leave binaries in build/sitl-debug/bin
… and you know they work that way
Ben
Yours,
Hey Peter. Thanks!
You sent me to his main page. Is there a specific note that I should look for?
In any case… Do I need to rebuild sitl or just the copter. If its the latter - how do I point sitl to the new copter from the command line and from a python script?
I tried the test and this is the result??
ubuntu@ip-172-31-36-30:~/sitl/ardupilot$ ./Tools/autotest/autotest.py --debug build.ArduCopter fly.ArduCopter
Traceback (most recent call last):
** File “./Tools/autotest/autotest.py”, line 18, in **
** import apmrover2**
** File “/home/ubuntu/sitl/ardupilot/Tools/autotest/apmrover2.py”, line 7, in **
** import pexpect**
ImportError: No module named pexpect
The sim_vehicle thing was more successful:
Init APM:Copter V3.6-dev (624aef40)
Firmware change: erasing EEPROM…
done.
load_all took 0us
0 0 0 validate_structures:209: Validating structures
DataFlash_File: buffer size=16384
online system 1
STABILIZE> Mode STABILIZE
APM: Calibrating barometer
APM: APM:Copter V3.6-dev (624aef40)
APM: Frame: QUAD
Received 887 parameters
Saved 887 parameters to mav.parm
APM: Barometer calibration complete
Init Gyro***
Ready to FLY APM: GPS 1: detected as u-blox at 115200 baud
fence breach
APM: EKF2 IMU0 initial yaw alignment complete
APM: EKF2 IMU1 initial yaw alignment complete
APM: EKF2 IMU0 tilt alignment complete
APM: EKF2 IMU1 tilt alignment complete
APM: EKF2 IMU0 Origin set to GPS
APM: EKF2 IMU1 Origin set to GPS
APM: EKF2 IMU0 is using GPS
APM: EKF2 IMU1 is using GPS
Flight battery 100 percent
So that means I can fly sitl with copter 3.6-dev. right?
How do I do that from a drone-kit sitl command?
How do I do it from Python?
I want to thank you again so much for your help on this.
Depends on the script. But the (master!) dronekit-sitl constructor takes
an argument to specify which binary to use.
This dronekit-python script takes a --binary
option:
https://github.com/dronekit/dronekit-python/blob/source-system-filtering/examples/avoidance/avoidance-manytests-plane.py#L26
–debug build.ArduCopter fly.ArduCopter
in **
** import pexpect**
Fix that with either your package manager or pip
Yes.
See script mentioned above
Ah… dronekit-sitl is Python?!
No worries
Peter
Hi Peter,
Thanks again for the help. When I start the copter that I built in sitl it fails pre-arm checks. Is it because it is the 3.6? How do I compile ardupilot with copter 3.5 stable? I
Best,
Ben
git checkout Copter-3.5
Perhaps if you pasted in the text of the pre-arm failure I could help
diagnose that
Ben
Peter
Visit Topic or reply to this email to respond.
In Reply To
[45.png]
peterbarker
December 13 In any case… Do I need to rebuild sitl or just the copter. If
line and from a python script? Depends on the script. But the (master!)
dronekit-sitl constructor takes an argument to specify which binary to use.
This drone…
You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here.
Peter Barker | Programmer,Sysadmin,Geek.
pbarker@barker.dropbear.id.au | You need a bigger hammer.
:: It’s a hack! Expect underscores! - Nigel Williams
Hi ,
I took some time off of trying to fly my SITLs in the cloud but I am back at it. I got to a point where I can successfuly build arducopter on an ubuntu server on AWS. I do this with:
./waf configure
./waf copter
I then run sitl and here is the output that I get when I connect to it from a ground station or a script:
Frame: UNKNOWN
PreArm: check firmware or FRAME_CLASS
PreArm: 3D Accel calibration needed
PreArm: Compass not calibrated
PreArm: RC Roll not configured
PreArm: RC Pitch not configured
PreArm: RC Throttle not configured
PreArm: RC Yaw not configured
Can anyone help with this?
Thanks -
Ben
