Hello I am trying to connect my rover via Drone python kit , so i was told that the best way to do it ,i is to call the file in the command prompt using admin privileges
I have been trying to do that but it say “no such file or directory” i have been trying to figure out how to change the directory or path with no luck , I created a folder for which my code is saved under but I still have not been able to call on it . Can someone please help Thank you !
nevermind i got it to change directory lol i was i typing it in wrong , did not realize it was case and space sensitive
But it still saying the file i am looking for is not in that directory . When i look under the properties of the file is say it in that directory that i change it too
i dont get it
ok cool thanks that worked perfectly and now its reading the file but it keep saying permission denied . looking it on google but have not found anything yet . im using the right “com” and i thought since im using the admin cmd prompt it should override everything
okay i have the mission planner application open and it calls that port “com8” . that may be the reason, so should I have mission planner closed when trying to using Dronekit ?
okay gotchu so i was having it connected so i disconnected it and reran the code but now it says "no module named serial " I been checking everything making sure i was using the right code and com port and it seems like i am but something still is off
okay got it ! just downloaded it . it made a small difference . the first time i ran it i gave e that message in the image but now it not saying anything and I don’t believe its connecting anything
