as i had a bad experience with a cellular-based tracker, i experienced many sub-urban places doesn’t have cellular coverage. I decided to use Lora long-range radio module on this.
And i found very interesting GPS module which is super tinySIM33ELA with built-in antenna.
I connect them all to a small low power STM32 microcontroller.
by adding few more things, like battery charging from micro USB, buzzer, LED overall come in 17 mm x 32 mm size.
I will post more information after i got the PCBs on my hand. stay tune now
I am not sure if need a interface for FC. I am thinking stand allon super small long battery life device wil be better, not just for drones also to any equipment that you want to track. Even though, if there is no GPS coverage in the zone, still will get the signal strength to find the location
Thank you very much, currently electronic side i have finished, not so complicated, i will update after finishing 1 st protoype) i am just worrying a little bit on GPS module, first time i will try this micro gps, hope its performance will be sufficient enough)
I think it should be ok. If it catches even one satellite, you are good.
The trick is to maintain the last satellite location stored inside the memory prior the plane/drone crash and being able to transmit that location not the 100% actual crash location, if and only if, if the tiny GPS still getting any GPS data after the crash.
nice idea, i will add many features, like, distance with radio signal, even though there is no GPS data i will be able to find the distance. Buzzer activate/ deactivate. Sleep mode for battery saving.
I so excited to get my hands on coding this device)
There was some guy in Russia who developed something similar but he failed miserably later on at least for me. I bought 4 of his units and couldn’t get them to work. The product name was tbeacon. His documentation sucks
there will not be triggering , just a ON/OFF button on the module. as a small battery enough for weeks, i think triggering is not needed.
it is a question for me too, it will be clear after i got my prototype working )
but i believe will be +8km, Lora has very good penetration
receiver i am planning a small Lora module with Bluetooth, and will be able to transmit gps data to smartphone and show the location on the map.
actually i used tbeacon as well, what i didnt like about it is the radio station, you need to call the beacon and listen the voice, and range isnt good .
