Drone set up with the methodic configurator
Wlile following the methodic configurator,on the 12th it tells you you to close it and use M.P. where in the “initial tune parameters” page i get only a few parameters changed.But in the M.C.
Page shows a lot of them being changed.
Is there any problem??
Thank you
No, there is no problem at all, the MC already set the values correctly, so MP has nothing to change. This is both desired and expected.
Those 4 values are not a real change, look at it closely and you will see that the values are the same for all practical intents and purposes.
This is just a proof that MC did the correct changes
