I have an SDR Solo loaded with OpenSolo 4.0 which I believe is an Ardupilot version
I can receive messages from my drone and decode them but it does not respond to messages I send using the mavlink c header files. I have posted this problem on the mavlink forum thinking it is a mavlink issue but a post I read over there suggested that it might be a Ardupilot specific issue.
It would be great if any window users would download the test tool run it and let me know the results. It is not a polished tool (yet) but it seems to work other than no change in the drone status. I compared the basic message structure to that created by QGroundControl and it seems to be the same. I have not found examples on setting the ck and signature parts of the message structure but I took a quick stab at setting them. Is there a specific sequence required by Ardupilot for starting?
The problem was a version issue. The Arducopter that was loaded with the OpenSolo firmware update is using mavlink v1… I was using mavlink v2. While I could receive and decode the messages the drone was rejecting everything I send because it had the 0xfd magic number and the drone expected 0xfe
The issues that were fixed according to the readme did not include upgrading to V2
Unfortunately when I tried to upgrade to the 4.3.7 using solex, I get the message “Package is not compatible with this vehicle” I got the same message when I tried to load 4.0.3.
My solo is a stock / original Solo which I think I read somewhere is a pixhawk 2
Amilcar:
Thanks for your help. I walked through the process again and it seemed to do all of the steps but when I restart the system the controller still shows OpenSolo 4.0 and the “magic number” or sync byte still shows up as 0xfe instead of the 0xfd as expected.
