Hello I’m am trying to use the drone kit python to connect to my vehicle but I am running into a issue connecting it via usb, i have tried the scripts that our on there website but haven’t been successful. a few times it said “permission denied” . On mssion planner my usb is labeled "com8 " . Can someone help ? maybe i am missing something .
thank you!
Did you set the baud rate when connecting it using dronekit? Also try to run the python script from command line window which started with admin privileges. You have some permission issues I think.
no I didn’t , where do you set the baud rate in the code, ii didn’t see that step when reading for connecting via USB .
Yea i tried that the first time, it didn’t work but I can try it again , should I call the file inside the command the command file instead of typing the script out?
