I’ve just rebuilt my drone onto a DJI F450 airframe, after repeatedly destroying a home made version. I’ve flashed my APM and re-installed 3.1, run through the full set up again, just in case.
After arming, when I throttle up, it wants to flip to its right side.
Go over your setup. Make sure you have your frame set for x or +.
Check your motor wiring order, make sure your props are correct, make sure motors are spinning the right direction.
