Hi all,
My Drone is flying well, but suddenly it decreased its altitude and crashed in loiter mode. From visual aspect it is like it loosed altitude due to a motors stops suddenly/ speed decreased that’s why it crashed. I might be wrong. But the point why the motors are behaving like this? We have faced couple of this type of incident frequently, could not find any remedy. Went through certain link, all are suggesting there might be a esc motor issue. The questions that is the only problem or anything else we missed to find. and we found this type of problem many times.
I am attaching the link of the log
Kindly help me to find out the reason for the crash.
Thanks in advance.
Like if I re-emphasize correctly that we have seen this happen repeatedly in the recent past with a variety of components, basically we use different brand’s motors with relevant ESC also.
All showing the same signature that one motor thrust drops and the diagonally opposite one goes down to compensate. Could there be something systematic in our flight parameter settings which could be causing this? Or some other generic thing that we’re systematically doing wrong that could be affecting all drones in the same manner?
Thrust loss could be caused by several different things that are not clear from a log. Failed motor, ESC, prop, solder joint, etc. Or it could be a de-sync. Poor quality build and/or the components perhaps.
Got any of this junk? Hardware to avoid
