aviram120
(aviram120)
August 19, 2015, 2:16pm
1
Hi
I have pixhawk modle and i want him connetc to my Droidplaner(from android phone) via wifi.
for this, i will purchase this model :
sparkfun.com/products/10822
sparkfun.com/products/11373
But my Question is: if Droidplaner can work via wifi?
There is a possibility to change anything in the code to make this change?
Thanks
Aviram
parkgt
(parkgt)
August 22, 2015, 3:52am
2
Even if you could why would you want to since wifi range is so limited?
billb
(Bill Bonney)
August 24, 2015, 6:41pm
3
Yes it works with DroidPlanner and MAV Pilot for iOS. I have setup instructions here communistech.com/support/
Thought that is a little different as it also uses a 3DR Radio to make it longer range.
Hope that helps
govsux
(govsux)
October 15, 2015, 11:18pm
4
[attachment=0]IMG_4948.JPG[/attachment]I did that very thing with help from Bill . Could only get it set to work via UDP but I’m sure it was just me setting it up. Works great!
billb
(Bill Bonney)
October 15, 2015, 11:44pm
5
UDP is better as then you don’t need a connect/reconnect option. As soon as the WiFi network is connected data flows
