I just downloaded The Mission Planner zip file along side w/Mono but cant launch it using the command mono MissionPlanner.exe. Here is the full paragraph i get. Btw I’m using M2 Macbook.
If your error is about Microsoft.DirectX.DirectInput, please install the latest directx redist from here http://www.microsoft.com/en-us/download/details.aspx?id=35
Debug under mono MONO_LOG_LEVEL=debug mono MissionPlanner.exe
To fix any filename case issues under mono use export MONO_IOMAP=drive:case
for pinvoke MONO_LOG_LEVEL=debug MONO_LOG_MASK=dll mono MissionPlanner.exe
watch -n 1 ls -l /proc/$(pidof mono)/fd
watch -n 1 lsof -p $(pidof mono)
Data Dir /Users/gorkem/.local/share/Mission Planner/
Log Dir /Users/gorkem/.local/share/Mission Planner/logs
Running Dir /Users/gorkem/Downloads/MissionPlanner-latest/
User Data Dir /Users/gorkem/.local/share/Mission Planner/
PlacesRecentDocuments Dir
PlacesDesktop Dir /Users/gorkem/Desktop
PlacesPersonal Dir /Users/gorkem
PlacesMyComputer Dir
WARNING: The Carbon driver has not been ported to 64bits, and very few parts of Windows.Forms will work properly, or at all
INFO MissionPlanner.Program - ******************* Logging Configured *******************
INFO MissionPlanner.Program - /Users/gorkem/Downloads/MissionPlanner-latest/x64/libSkiaSharp
ERROR MissionPlanner.Program - System.DllNotFoundException: libdl.so assembly: type: member:(null)
at (wrapper managed-to-native) MissionPlanner.Utilities.NativeLibrary.dlopen(string,int)
at MissionPlanner.Program.Start (System.String args) [0x0044f] in <91ac89d2443e43b68c8e690d54351a73>:0
Fontconfig warning: ignoring UTF-8: not a valid region tag
Native Crash Reporting
Got a segv while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Native stacktrace:
0x10468a679 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_dump_native_crash_info
0x10462240e - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_handle_native_crash
0x1046847f6 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : altstack_handle_and_restore
0x7ff8064fcaa7 - /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight : SLDisplayBounds
0x1164b34b8 - Unknown
0x112d4ed66 - Unknown
0x10457f352 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_runtime_invoke
0x1047907e2 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_try_invoke
0x10478f408 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_class_init_full
0x104576d5c - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_compile_method_inner
0x10457a8aa - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_compile_method_with_opt
0x104624f2e - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : common_call_trampoline
0x104624970 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_magic_trampoline
0x10d500393 - Unknown
0x11634153b - Unknown
0x1163a5168 - Unknown
0x115601dbb - Unknown
0x10d5890b3 - Unknown
0x10478ee07 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_runtime_invoke_checked
0x10479731e - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : do_exec_main_checked
0x1045dfabe - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_jit_exec
0x1045e2d25 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : mono_main
0x10456eb78 - /Library/Frameworks/Mono.framework/Versions/6.12.0/bin/mono-sgen64 : main
0x204a0d386 - Unknown
Telemetry Dumper:
Pkilling 0x13106143232x from 0x8668262976x
Entering thread summarizer pause from 0x8668262976x
Finished thread summarizer pause from 0x8668262976x.
Failed to create breadcrumb file (null)/crash_hash_0x9f0b05dbc
Waiting for dumping threads to resume
External Debugger Dump:
Basic Fault Address Reporting
Memory around native instruction pointer (0x7ff8064fcaa7):0x7ff8064fca97 89 fb 48 8b 05 88 48 ea 3b 0f 10 00 0f 10 48 10 …H…H.;…H.
0x7ff8064fcaa7 0f 11 4f 10 0f 11 07 89 f7 48 89 de e8 11 d3 f9 …O…H…
0x7ff8064fcab7 ff 48 89 d8 48 83 c4 08 5b 5d c3 55 48 89 e5 53 .H…H….UH…S
0x7ff8064fcac7 48 83 ec 28 48 8b 05 f6 61 e9 3b 48 8b 00 48 89 H…(H…a.;H…H.
Managed Stacktrace:
at <unknown> <0xffffffff>
at System.Windows.Forms.XplatUICarbon:CGDisplayBounds <0x000b7>
at System.Windows.Forms.XplatUICarbon:get_WorkingArea <0x00072>
at System.Windows.Forms.XplatUICarbon:get_VirtualScreen <0x00043>
at System.Windows.Forms.XplatUI:get_VirtualScreen <0x00048>
at System.Windows.Forms.Screen:.cctor <0x0017a>
at System.Object:runtime_invoke_void <0x000a5>
at System.Windows.Forms.Form:get_CreateParams <0x0062a>
at System.Windows.Forms.Form:SetClientSizeCore <0x001c7>
at System.Windows.Forms.Control:set_ClientSize <0x00048>
at System.Windows.Forms.Form:set_ClientSize <0x00052>
at System.Windows.Forms.Form:UpdateWindowText <0x00082>
at System.Windows.Forms.Control:set_Text <0x000ac>
at System.Windows.Forms.Form:set_Text <0x0004a>
at MissionPlanner.Splash:InitializeComponent <0x00b10>
at MissionPlanner.Splash:.ctor <0x0005a>
at MissionPlanner.Splash:.ctor <0x0006a>
at MissionPlanner.Program:Start <0x014e2>
at MissionPlanner.Program:Main <0x00042>
at <Module>:runtime_invoke_void_object <0x000b0>
zsh: abort mono MissionPlanner.exe
