wcfung1
(Frankie Fung)
July 27, 2020, 2:06am
#1
My quad 250 is running Revo and among different download errors, this is the first time I see such error message. See attached 2 screen shots, plus my log parameter setting.!
Error message__download DF logs|690x387 !
Error messgae__Message tab|690x387 !
Log param|690x387
Other than this error, I have not been able to download the Log Analyzer for quite a while, and I could not get any help from the forum.
Appreciate any help.
We have a rather large number of bugfixes in a PR from @andyp1per here: https://github.com/ArduPilot/ardupilot/pull/14299/files
If you’re in a position to help test that branch, it would be appreciated.
wcfung1
(Frankie Fung)
July 27, 2020, 5:56am
#3
I have benefited from the forum so far, and I would like to help. However I do not have any background in coding and programming.so I don’t know how I can help.
Frankie
andyp1per
(Andyp1per)
July 27, 2020, 8:08am
#4
I can do you a build of master if you would like to test. Which exact flight controller do you have?
wcfung1
(Frankie Fung)
July 27, 2020, 3:37pm
#5
I have Revo full size on quad and planes. What is build of master ?
andyp1per
(Andyp1per)
July 27, 2020, 3:59pm
#6
master is the the latest development commit, i.e. it is not a stable version like 4.0.3 for instance
andyp1per
(Andyp1per)
July 27, 2020, 8:45pm
#7
I only see revo-mini in the build options. What firmware do you generally download?
wcfung1
(Frankie Fung)
July 27, 2020, 10:19pm
#8
Revo mini and revo full size use the same firmware. I never have any Revo mini board.
For my full size Revo, I also download the Revo mini fw, usually copter and plane. The Revo mini fw works with Revo full size.
I am also experimenting on Copter-heli with Revo.
andyp1per
(Andyp1per)
July 28, 2020, 9:30pm
#9
Here is a build of master with these fixes in for copter. You will need to unzip before trying to load on your FC:
arducopter.zip (580.9 KB)
Since this is alpha software I only recommend using this to verify that the fixes solve your problem, although I fly with master all the time without issue.
wcfung1
(Frankie Fung)
July 31, 2020, 4:08am
#10
I have been wondering the kind of help which I can offer, without any coding or programming knowledge.
Now I know it is to test fly the copter with a firmware under testing. The copter I have is experiencing toilet bowl effect
and from time to time, it tilts to one side after landing. Is this an ideal vehicle to test new firmware ?
