Doesn't stop drone at Avoid Margin distance
I have configured Proximity sensor for obstacle avoidance function and configured
Avoid enable = 3
Avoid_behave= 1 ( stop)
Avoid_margin = 15 meter( kept high because of flying speed also High)
I was tried to do the Avoid function in loiter Mode at 10m/s speed and drone expected to stop at 15m before the obstacle, but due to high speed the drone could not able to stop at Avoid_ Margin distance and it come very close to the obstacle almost 1meter distance.
If i fly the drone on low speed it can able to stop at desired point some how .
What parameter will make the smoother stop at 15m when flying speed at 10m/s.
How to deaccelarate smoothly?
Change the LOIT_BRK_* parameters
More aggressive stop in loiter mode?
Yeap. And a better PID tuning will also allow you to stop faster.
Hi, @kalai1219 we have also noticed that in auto flights the drone does not stop if the speed is 10m/s. It stops if is it 8m/s.
Did you understand the reason for this?
@Shubham_Saboo
The acceleration is not considered
