Does SET_POSITION_TARGET_LOCAL_NED work for arduplane
Does SET_POSITION_TARGET_LOCAL_NED work for arduplane in guided mode, or offboard control. I can see examples of it for arducopter but i cant find any details to the for ardu plane. I am new here but i want to update my craft from my Raspberry PI.
Not for plane, only copter implements it at the moment.
Thanks, i was trying to find a way to control the plane using a companion but i will have to stick with lat, lon
You have to use the MAV_CMD_NAV_WAYPOINT command that is use with the built in simple_goto in dronekit.
Here is the link:
http://ardupilot.org/dev/docs/plane-commands-in-guided-mode.html
Hope this helps.
Pat
