I see your on the install firmware screen and there is a port selected. Are you trying to load firmware or is the firmware already loaded?
Mike
it is solved now. I forced bootload on it.
could you explain more specifically how to solve it? I have same problem.
I believe he was trying to load the firmware but the unit he had was locked up for some reason. This prevents it from being able to load the firmware.
By holding down the RED button and powering on the unit he forced it into boot loader mode which then allowed the firmware to load. IE a bricked unit.
Mike
It works. Thanks a lot
