DO_SET_ROI no longer exists?
Hello
Mission Planner 1.2.95, the command DO_SET_ROI no longer exists.
Why?
greeting
Rainer
please connect to the AP, and it should be there
Hello
try it out, the command does not exist.
Please ask Randy.
greeting
Rainer
I’ve also found that it’s gone missing. I was strangely able to make it appear by loading an older mission that had a do-set-servo command in it. Once I did that, then it started appearing in the command drop-down list.
…so pretty sure it’s a mission planner issue.
please try the latest MP.
make sure the last thing you wqhere connected to was a arducopter, as the options change if you where last connected to arduplane.
