I’m not able to have the “do mount control” command working in mission planner missions while my servo gimbal works fine.
My set up :
Pixhawk
Servo gimbal 2 axis
I have some questions :
In gimbal configuration page , do the tilt input ch must be disable ?
In gimbal configuratation page I have 1000 and 1950 ms as servo limits and -15 and 15 as angle limits ;
what are the values that the do mount control will accept , they must be in the range -15 to +15 or the values are not related to angle limits ?
Also DO_SET_SERVO command do not seems to work . Any ideas ?
I have a problem with DO_MOUNT_CONTROL. I can add the command and save it to the drone but when I read the file from drone it shows the Pitch, Roll, Yaw as (0,0,0) although I set as 90,0,0. When saving to disk on laptop the parameters stay but when written to drone they revert back to 0. I am using a Walkera Tali H500 with MP.
