I am building a quadplane that uses an Intel T265 tracking camera to localize the drone. I have a Raspberry PI 3 connected to a Pixhawk via a serial connection (921000 baud). The tracking camera is sending POSE data through the PI to the Pixhawk at 30 hz, additionally, I have a set of Python scripts meant to control the drone autonomously, within the scripts it is continuously requesting telemetry data from the Pixhawk and storing, while also sending command messages to the pixhawk approximately every few seconds. I am worried that the single serial connection will not be able to handle all of this traffic at once without messages getting lost in transmission. Is it worth setting up a dedicated serial connection just for the POSE data and then another for the autonomy scripts, or would a single serial connection be sufficient? If anyone knows this I would appreciate it, or a workaround to synchronize the messages. Thanks!
Thanks for the reply I appreciate it. By “continuously requesting telemetry data”, I have a script that request position, velocity and a few other sets of data from the Pixhawk, the rate at which I do this can be adjusted, it only effected the accuracy of the python scripts running on the PI.
