Hi, im using a DLVR-L10D airsensor on my set up. Its connected via a Matek M8Q-CAN GPS. My goal is to use the sensor with only stagnation pressure connected and get static pressure from the fuselage. Do anyone know which port is the top and bottom in ARSP_TUBE_ORDER in UAVCAN parameters? Are there any complications with connecting the pivot tube like this?
Im also getting a bad BARO health warning because of the integrated baro in the gps.
Cheers Jan Rune
