has anyone experienced lagging of OSD with DJI Goggles 2 and Vista/Air Units?
Today I tried two planes with this setup, and on one all was fine but on the other the OSD was lagging a lot - AHI took a while to adjust, current values etc.
I wonder if maybe this is DMA issue? The FC with problems is F405STD and the one without is F405WSE… I still need to check if on the WSE DJI is connected to DMA port.
Hi @jaroszmm
How was the transmission/data rate when you are having this lag ?
What is the distance between you and the flying device ? I just have problems with the OSD info when the data rate is lower than 1M.
Sorry, missed the notification.
I was pretty close, like maybe below 500m away.
I noticed the same issue on three AP planes with Vistas but no issue on Air Unit.
50mbps most of the time.
