The goggles should start recording video after arming the quad by default, but they don’t. Pressing the record button doesn’t seem to work either. Checking the contents of the SD card shows an empty folder named ‘Lost.Dir’
Are there any additional settings that need to be configured on Ardupilot? Here is my current config: latest_params.param (19.8 KB)
I’m using a 128GB SD card which I formatted (in the goggles) (Amazon.com)
It works for me. Does any other OSD info work for you? You have to be careful with later versions of the firmware as there are two modes and I think only one works with AP.
@andyp1per Yes all other OSD info shows up as expected. I had to downgrade the firmware to make this work. Everything works except for saving to SD card.
