Hello. I can watch H16 pro MIPI camera video on VLC player with below address :
rtsp://192.168.43.1:8554/fpv_stream
but, How can I display this video in mission planner hud?
Right-click on HUD and “set Gstreamer source” didn’t work.
Download gstreamer and put together a gstreamer pipeline that works with your video source, then add this pipeline to MP.
Sorry, I downloaded gstreamer but couldn’t find executable files. maybe it needs to know special command prompt line to run this.
(1)
rtspsrc location=rtsp://192.168.43.1:8554/fpv_stream ! decodebin ! autovideosink
I put this prompt in “set gstreamer source” menu and it gives me seperate video display window, not in hud.
(2)
also I tried something like this(I changed many options)
rtspsrc location=rtsp://192.168.43.1:8554/fpv_stream ! decodebin ! videoconvert ! video/x-raw,format=RGB ! appsink name=outsink
but they didn’t work.
I’m debugging error messages on console but have no clue.
Below prompt also works, but it display seperate window to display video :
rtspsrc location=rtsp://192.168.43.1:8554/fpv_stream ! decodebin ! videoconvert ! video/x-raw,format=BGRA ! autovideosink
ERROR MissionPlanner.Utilities.GStreamer - gst_parse_launch: could not link autovideosink8 to outsink
This error message for below prompt :
rtspsrc location=rtsp://192.168.43.1:8554/fpv_stream ! decodebin ! videoconvert ! video/x-raw,format=BGRA ! autovideosink ! appsink name=outsink
rtspsrc location=rtsp://192.168.43.1:8554/fpv_stream ! decodebin ! videoconvert ! video/x-raw,format=BGRA ! appsink name=outsink
above prompt generates below error messages on console :
child ‘rtspsrc3’ changed state to 4(PLAYING) successfully
0:01:15.307499900 INFO MissionPlanner.Utilities.GStreamer - set playing
INFO MissionPlanner.Utilities.GStreamer - start frame loop gst_app_sink_is_eos
20412 0000015C4CF0A280 INFO rtspsrc gstrtspsrc.c:7360:gst_rtspsrc_retrieve_sdp: Now using version: 1.0
0:01:15.318713500 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:01:15.322788400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0000015C416C2000 adding pad ‘src’
0:01:15.326146000 20412 0000015C4CF0A280 INFO udpsrc gstudpsrc.c:1408:gst_udpsrc_open: setting udp buffer of 524288 bytes
0:01:15.329154900 20412 0000015C4CF0A280 INFO udpsrc gstudpsrc.c:1428:gst_udpsrc_open: have udp buffer of 524288 bytes
0:01:15.330259100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:01:15.330836900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:01:15.331803300 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsrc”
0:01:15.332477900 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0000015C4CF4CC90 adding pad ‘src’
0:01:15.333190300 20412 0000015C4CF0A280 INFO udpsrc gstudpsrc.c:1428:gst_udpsrc_open: have udp buffer of 65536 bytes
0:01:15.333777500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to READY
0:01:15.334351900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (VOID_PENDING pending)
0:01:15.344453200 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “rtpbin” named “manager”
0:01:15.348391400 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:01:15.351697100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:01:15.353972500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:01:15.354585700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:01:15.355197100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:01:15.357009200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtp_sink_0’ in element “manager”
0:01:15.359243300 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpsession”
0:01:15.360143200 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpssrcdemux”
0:01:15.360760600 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpSsrcDemux@0000015C41637E60 adding pad ‘sink’
0:01:15.361376400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpSsrcDemux@0000015C41637E60 adding pad ‘rtcp_sink’
0:01:15.362019600 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “rtpstorage”
0:01:15.362900000 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpStorage@0000015C4163C7E0 adding pad ‘src’
0:01:15.364123800 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstRtpStorage@0000015C4163C7E0 adding pad ‘sink’
0:01:15.364733000 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:01:15.365345500 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstFunnel@0000015C4163CEA0 adding pad ‘src’
0:01:15.365945200 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “funnel”
0:01:15.366552100 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstFunnel@0000015C4163C240 adding pad ‘src’
0:01:15.367242700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:01:15.367825600 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:01:15.368430500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:01:15.369029100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:01:15.369626500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:01:15.370232200 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:01:15.370829300 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:01:15.371429400 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:01:15.372302600 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:01:15.373803100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:01:15.374566600 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:01:15.376524700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:01:15.377105300 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:01:15.377683200 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:01:15.378366900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:01:15.379062800 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:01:15.379635200 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:01:15.380210200 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:01:15.380782400 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:01:15.381354900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:01:15.381931100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PAUSED, next PAUSED
0:01:15.382504900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PAUSED pending)
0:01:15.383079900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PAUSED
0:01:15.383653000 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PAUSED
0:01:15.384224700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:01:15.384800600 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtp_sink’ in element “rtpsession1”
0:01:15.385389600 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_sink’
0:01:15.385967200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_src’
0:01:15.386559100 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘funnelpad2’
0:01:15.387124400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad funnel2:src
0:01:15.387692600 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link funnel2:src and rtpsession1:recv_rtp_sink
0:01:15.388264300 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked funnel2:src and rtpsession1:recv_rtp_sink, successful
0:01:15.389516500 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.391170600 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link recv_rtp_sink_0:proxypad13 and funnel2:funnelpad2
0:01:15.392944700 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked recv_rtp_sink_0:proxypad13 and funnel2:funnelpad2, successful
0:01:15.393505100 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.394508200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtp_sink_0’
0:01:15.395099300 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpsession1:recv_rtp_src
0:01:15.395666800 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpstorage1:sink
0:01:15.396261100 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpsession1:recv_rtp_src and rtpstorage1:sink
0:01:15.396852600 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:4232:gst_pad_peer_query:rtpstorage1:src pad has no peer
0:01:15.397425100 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpsession1:recv_rtp_src and rtpstorage1:sink, successful
0:01:15.397984400 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.398558200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpstorage1:src
0:01:15.399120700 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpssrcdemux1:sink
0:01:15.399685600 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpstorage1:src and rtpssrcdemux1:sink
0:01:15.400249800 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpstorage1:src and rtpssrcdemux1:sink, successful
0:01:15.400807800 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.401390900 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtcp_sink_0’ in element “manager”
0:01:15.401955800 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘recv_rtcp_sink’ in element “rtpsession1”
0:01:15.402542500 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtcp_sink’
0:01:15.403120200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘sync_src’
0:01:15.403700800 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘funnelpad3’
0:01:15.404262400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpsession1:sync_src
0:01:15.404823100 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad rtpssrcdemux1:rtcp_sink
0:01:15.405517800 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpsession1:sync_src and rtpssrcdemux1:rtcp_sink
0:01:15.407113000 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpsession1:sync_src and rtpssrcdemux1:rtcp_sink, successful
0:01:15.408875600 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.410571700 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad funnel3:src
0:01:15.411256200 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link funnel3:src and rtpsession1:recv_rtcp_sink
0:01:15.411833100 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked funnel3:src and rtpsession1:recv_rtcp_sink, successful
0:01:15.412397900 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.413005500 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link recv_rtcp_sink_0:proxypad14 and funnel3:funnelpad3
0:01:15.413569600 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked recv_rtcp_sink_0:proxypad14 and funnel3:funnelpad3, successful
0:01:15.414130500 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.414703300 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘recv_rtcp_sink_0’
0:01:15.415286300 20412 0000015C4CF0A280 INFO rtspsrc gstrtspsrc.c:3629:gst_rtspsrc_stream_configure_manager: configure bandwidth in session 0000015C42E328F0
0:01:15.415894000 20412 0000015C4CF0A280 INFO rtspsrc gstrtspsrc.c:3635:gst_rtspsrc_stream_configure_manager: setting AS: 1000.000000
0:01:15.416536200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsrc2:src
0:01:15.417104500 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link udpsrc2:src and manager:recv_rtp_sink_0
0:01:15.417670600 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked udpsrc2:src and manager:recv_rtp_sink_0, successful
0:01:15.418231500 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.418794700 20412 0000015C4CF0A280 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:udpsrc2:src Received event on flushing pad. Discarding
0:01:15.419416800 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsrc3:src
0:01:15.419984500 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link udpsrc3:src and manager:recv_rtcp_sink_0
0:01:15.420550000 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked udpsrc3:src and manager:recv_rtcp_sink_0, successful
0:01:15.421111500 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.421675400 20412 0000015C4CF0A280 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:udpsrc3:src Received event on flushing pad. Discarding
0:01:15.423298800 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:01:15.425322400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0000015C416D5880 adding pad ‘sink’
0:01:15.428152700 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “fakesrc”
0:01:15.429107400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSrc@0000015C4CF218F0 adding pad ‘src’
0:01:15.429734400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakesrc1:src to element udpsink2:sink
0:01:15.430289400 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakesrc1:src
0:01:15.430842100 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsink2:sink
0:01:15.431399200 20412 0000015C4CF0A280 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakesrc1 and udpsink2 in same bin, no need for ghost pads
0:01:15.431965200 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakesrc1:src and udpsink2:sink
0:01:15.432523900 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakesrc1:src and udpsink2:sink, successful
0:01:15.433077500 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.433635500 20412 0000015C4CF0A280 INFO GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:fakesrc1:src Received event on flushing pad. Discarding
0:01:15.434326400 20412 0000015C4CF0A280 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “udpsink”
0:01:15.434945300 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0000015C4CF4AC30 adding pad ‘sink’
0:01:15.436501700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:01:15.437089700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:01:15.437700900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:01:15.438319400 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:01:15.439807700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:01:15.440607100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:01:15.442006600 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:01:15.443608400 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:01:15.444201100 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad udpsink3:sink
0:01:15.444771200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘send_rtcp_src_0’ in element “manager”
0:01:15.445340000 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘send_rtcp_src’ in element “rtpsession1”
0:01:15.445931200 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘send_rtcp_src’
0:01:15.446524400 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link rtpsession1:send_rtcp_src and send_rtcp_src_0:proxypad15
0:01:15.447090700 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked rtpsession1:send_rtcp_src and send_rtcp_src_0:proxypad15, successful
0:01:15.447655400 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.448222300 20412 0000015C4CF0A280 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘send_rtcp_src_0’
0:01:15.448791100 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link manager:send_rtcp_src_0 and udpsink3:sink
0:01:15.449349100 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked manager:send_rtcp_src_0 and udpsink3:sink, successful
0:01:15.449905000 20412 0000015C4CF0A280 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:01:15.450483600 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:01:15.451083500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to NULL
0:01:15.451754100 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:01:15.452534800 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:01:15.453147000 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:01:15.453758800 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:01:15.454365000 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:01:15.454974500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:01:15.455679500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:01:15.456487700 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:01:15.457689500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from NULL to READY, pending PLAYING, next PAUSED
0:01:15.458786000 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed NULL to READY (PLAYING pending)
0:01:15.459538300 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change READY to PAUSED, final PLAYING
0:01:15.460156200 20412 0000015C4CF0A280 INFO basesrc gstbasesrc.c:1358:gst_base_src_do_seek: seeking: bytes segment start=0, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:01:15.460740200 20412 0000015C4CF0A280 INFO task gsttask.c:457:gst_task_set_lock: setting stream lock 0000015C416BE4B0 on task 0000015C4163C4D0
0:01:15.461298700 20412 0000015C4CF0A280 INFO GST_PADS gstpad.c:6154:gst_pad_start_task:fakesrc1:src created task 0000015C4163C4D0
0:01:15.462065900 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2651:gst_element_continue_state: committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:01:15.462977000 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed READY to PAUSED (PLAYING pending)
0:01:15.462454700 20412 0000015C4D10ACC0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink’ in element “fakesrc1”
0:01:15.465266000 20412 0000015C4D10ACC0 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:fakesrc1:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:01:15.465274000 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2658:gst_element_continue_state: continue state change PAUSED to PLAYING, final PLAYING
0:01:15.466866300 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2676:gst_element_continue_state: completed state change to PLAYING
0:01:15.467522500 20412 0000015C4CF0A280 INFO GST_STATES gstelement.c:2579:_priv_gst_element_state_changed: notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:01:15.466250600 20412 0000015C4D10ACC0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event bytes segment start=0, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:01:15.468936700 20412 0000015C4D10ACC0 INFO basesrc gstbasesrc.c:2945:gst_base_src_loop: marking pending DISCONT
0:01:15.470036900 20412 0000015C4D10ACC0 INFO basesrc gstbasesrc.c:2839:gst_base_src_loop: pausing after gst_base_src_get_range() = eos
0:01:15.470660800 20412 0000015C4D10ACC0 INFO task gsttask.c:316:gst_task_func:fakesrc1:src Task going to paused
0:01:15.471564100 20412 0000015C4CF0A280 WARN rtspsrc gstrtspsrc.c:6157:gst_rtspsrc_send: error: Unhandled error
0:01:15.472399300 20412 0000015C4CF0A280 WARN rtspsrc gstrtspsrc.c:6157:gst_rtspsrc_send: error: Session Not Found (454)
0:01:15.474072800 20412 0000015C4CF0A280 INFO GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details: posting message: Unhandled error
0:01:15.475357400 20412 0000015C4CF0A280 INFO GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details: posted error message: Unhandled error
0:01:15.477260100 20412 0000015C4CF0A280 WARN rtspsrc gstrtspsrc.c:8111:gst_rtspsrc_play: error: Could not send message. (Generic error)
0:01:15.478188000 20412 0000015C4CF0A280 INFO GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details: posting message: Could not write to resource.
0:01:15.478827200 20412 0000015C4CF0A280 INFO GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details: posted error message: Could not write to resource.
