I am looking to change the display of the Yaw values to be in Radians instead of degrees.
I could not find a way to change the parameters on the mission planner config tab as it seems that degrees are the only option.
So, I have downloaded the source code but could not find where the values are in the code.
Any assistance would be very much appreciated!
Add this to CurrentState.cs
[GroupText("Attitude")]
[DisplayText("Yaw (rad)")]
public float yawrad
//convert _yaw from degree to radians
get => (float)MathHelper.Radians(_yaw);
I will give this a try later. Thank you So much!
