The pop menu that appears when you change a parameter in the Quick Tab is too big or too tall, the point is that I can’t see or scroll the elements at the bottom and I can’t change the size. Is there something I should be doing? So far, I need to change the orientation of the screen to vertical every time I need to a change of parameter.
Image showing that I can’t access the parameters:
