I have modified the code so that I can receive 2 different temperature values in MP. It works perfectly!
But I also want to receive a pwm value in MP but the problem is that the values donāt get updated any more. It would be very helpful if someone could help me to debug this issue.
here is the Arduino code:
// Combined Code
#include <math.h>
#define TX_RATE_HZ 10
const uint8_t HEADER_BYTE = 0xFF;
uint32_t last_update_ms = 0;
uint8_t led_state = 0;
float calculateTemperature(int RawADC);
int readPWMValue();
void setup() {
Serial.begin(115200);
pinMode(LED_BUILTIN, OUTPUT);
void loop() {
uint32_t now = millis();
if (now - last_update_ms > 1000 / TX_RATE_HZ) {
int sensorValue1 = analogRead(A0);
int sensorValue2 = analogRead(A1);
float temperature1 = calculateTemperature(sensorValue1);
float temperature2 = calculateTemperature(sensorValue2);
uint8_t checksum1 = highByte((int)temperature1) ^ lowByte((int)temperature1);
uint8_t checksum2 = highByte((int)temperature2) ^ lowByte((int)temperature2);
int pwmValue = readPWMValue();
Serial.write(HEADER_BYTE);
Serial.write(highByte((int)temperature1));
Serial.write(lowByte((int)temperature1));
Serial.write(checksum1);
Serial.write(highByte((int)temperature2));
Serial.write(lowByte((int)temperature2));
Serial.write(checksum2);
Serial.write(highByte(pwmValue));
Serial.write(lowByte(pwmValue));
led_state ^= 1;
digitalWrite(LED_BUILTIN, led_state);
last_update_ms = now;
float calculateTemperature(int RawADC) {
float Temp;
Temp = log((10240000.0 / RawADC) - 10000.0);
Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp)) * Temp);
Temp = Temp - 273.15;
return Temp;
int readPWMValue() {
const int pwmPin = 2;
unsigned long pulseDuration = pulseIn(pwmPin, HIGH);
int pwmValue = map(pulseDuration, 1000, 2000, 0, 100);
return pwmValue;
Lua script:
-- Updated Lua Script for 2 Temp Sensors and PWM
local RUN_INTERVAL_MS = 50 -- 50ms == 20 Hz
local MAX_BUFFER = 128 -- prevent Lua timeout
local port = serial:find_serial(0)
local bad_frames = 0
port:begin(115200)
port:set_flow_control(0)
function update()
local bytes = {}
while port:available() > 0 do
bytes[#bytes + 1] = port:read()
if #bytes > MAX_BUFFER then
return update, RUN_INTERVAL_MS
end
end
if #bytes >= 12 then
local header1, high1, low1, checksum1, header2, high2, low2, checksum2, header3, highPWM, lowPWM, checksumPWM =
bytes[1], bytes[2], bytes[3], bytes[4], bytes[5], bytes[6], bytes[7], bytes[8], bytes[9], bytes[10], bytes[11], bytes[12]
local tempVal1 = (high1 << 8) | low1
local tempVal2 = (high2 << 8) | low2
local pwmValue = (highPWM << 8) | lowPWM
local calculatedChecksum1 = (high1 ~ low1) & 0xFF
local calculatedChecksum2 = (high2 ~ low2) & 0xFF
local calculatedChecksumPWM = (highPWM ~ lowPWM) & 0xFF
if header1 == 0xFF and checksum1 == calculatedChecksum1 and
header2 == 0xFF and checksum2 == calculatedChecksum2 and
header3 == 0xFF and checksumPWM == calculatedChecksumPWM
then
gcs:send_named_float('TempVal1', tempVal1)
gcs:send_named_float('TempVal2', tempVal2)
gcs:send_named_float('PWMValue', pwmValue)
else
bad_frames = bad_frames + 1
gcs:send_named_float('BAD_FR', bad_frames)
end
end
end
return update()
