Hi!
I want to disable the beeping of the motor (beep-beep) before pressing the safty switch or arming and after disarming.
there is any option to disable it?
thanks, Omri
The beeping from the motors is a function of the ESC, not Ardupilot.
It is there as a safety measure to indicate the motor is live and has power but no PWM signal.
Maybe some ESC might exist out there that doesn’t but it is not a good idea.
It is a safety measure.
I know that the beeping is for safety but I need to disable it for experiment. there is any option to do it?
what experiment.
Anyway try playing with this setting…
[Beep strength:
Sets the strength of beeps under normal operation.]
…in Blheli suite.
I need the drone to wait in the takeoff position about an hour and then takeoff but I need it to be quiet when it in disarmed. is it possible ?
As said, it is an esc feature, there is nothing AP can do to disable it.
Need to take a look at esc manual to find out but i don’t recall i have ever seen a parameter to disable it in any esc i dealt with.
