Hi All,
My motor has the following encoder output signals.
The encoder is a A-B dual channel, 1000ppr, incremental optical encoder.
Encoder
Red +5V
Black GND
White A-
Blue A+
Yellow B-
Green B+
This is slightly different to the encoders used in the wiki. Can I simply use the +ve signals and ignore the negative signals and simply hook them up to my Navio2? –
Does the Navio2 support motor encoder input?
Also, I need to figure out the wheel’s distance from the flight controller. Do I figure out the position of the wheel based on the position of the axle as the reference point?
