Mission planners radius range is in meters and copter’s wp parameter is in centimeters, which one of the two is being used in a mission? Im very confused with this, any clarification is appreciated greatly. Thanks,
in the background they are the same param being adjusted.
Hey Michael,
Thanks for answering, so if i were to leave the field in MP at zero and copter’s parameter in lets say 20 cm, 20cm will be the hit radius?(I have an RTK gps and trying to get as close as i can).
yes, you can always confirm by reloading the params using the F5 key
AFAIK the minimum value of that parameter is 100cm. Anything smaller than that gets ignored and 100cm is used instead.
