The POI feature in Mission Planner is only there for visualization and is not used by AP in any way. You can clear them by deleting poi.txt in the documents/missionplanner folder.
As for 3, it should make no noticable difference to the user how the communication is done in the background to a gimbal.
Most Gimbals can’t rotate 360 degrees. As I recall, there are ArduPilot parameters that set the limits of movement on each gimbal axis. In fact The gimbal controller has limits too.
I’m wondering if this is taken into consideration when targeting with the gimbal.
For a copter that has the ability to yaw independently of flight path, it might be better to not rotate gimbal yaw at all - but orient the copter to face the target, and just use the gimbal to adjust pitch to target the desired altitude.
It may take some experimentation to figure this out, I don’t see comments or questions on this subject - it gives me the feeling that it isn’t something many people sort out any more.
Thank you - I’d pretty much figured this out before your response. Thank you for taking the time to respond - I hope it helps others who search the forum for questions about this,
