Im having a HELL of a time - getting message that barometer cant be initialized, disconnects when I try to calibrate the accel, and no response from the radio. Been using Matek boards with no issues, but this one has me stumped. Any words of wisdom?
The baro is a power issue - these boards really require battery power if you have anything at all connected. The bare board is just about ok, but with a GPS connected - forget it.
I’m assuming you are loading 4.4.4 which has support for this board.
Yes sir, 4.4.4 Ill power the board with battery then plug in after to see if that helps. With batt in Still not seeing the crsf on serial 1 (UART1) which has me scratching my head.
And just like that I figured it out. I need to power the board with battery before connecting to ARDU and then all is well with the system. This is going to be painful to program and not overheat the vtx and chew up batteries…last build with this board for me.
guys, I have a problem with the gyroscope, it doesn’t work. I downloaded inav and everything is fine, but when working on ardupilot it gives an error of poor gyroscope health and on telemetry the horizon is in a fixed position. And this happens every other time, sometimes it starts up well and everything works, but the next time it’s buggy. What to do ?
Mamba mk4 v2 h743_2022b dual icm-42688-p
Hello Today I tried to flash ArduCopter V4.6.0-dev and so far everything is working well. I will test further. Thank you very much for the recommendation!
by the way there is no mpu6000.
can you explain the difference between these firmwares? before that it was 4.5 stab
In general, I decided to flash it again to the stable version via mp and everything worked, but the settings were lost. The main thing is that it worked!
Hello, I can’t understand why the current sensor doesn’t work, I tried to calibrate it, but it either doesn’t show the upper currents correctly or the lower currents, let’s say when the power is turned on, it shows 0.3, and with a current consumption of 10 A, which I tracked with a laboratory power supply, it underestimated it twice that is, there were five amperes in the michon glider
