CraigElder
(Craig Elder)
1
Issues & Pull Requests
Plane
Copter
Rover
CraigElder
(Craig Elder)
2
Attendee count (max): 19
UTC1103 - Peter Hall is now a member of the dev team
UTC1104 - https://github.com/ArduPilot/ardupilot/pull/12235
- Let GPS log itself rather than replay logging
- Logging things twice when cores are offset
- Will also log all instances rather than just the primary core
- Replay only kinda works at the moment
- In the future, make Replay JUST log its inputs - not the batched sensor data
- Merged
UTC1109 - https://github.com/ArduPilot/ardupilot/pull/12234
- Rejig so it is all contained just within SITL
- Single threading SITL discussion
- We create an OSD thread and avoidance
- But there’s only one thread generally
- Can be merged once everything’s self-contained
UTC1113 - https://github.com/ArduPilot/ardupilot/pull/12218
UTC1116 - https://github.com/ArduPilot/ardupilot/pull/12214
UTC1117 - https://github.com/ArduPilot/ardupilot/pull/12200
- Sport PR
- Needs flight testing a bit
- Needs a longer review
- Register_param_table method coming
- Very light container format
- Variable-size
- Make it mavlink compatible?
- Alex Peter and tridge will have to discuss the approach later in the week
- Really looking forward to this going in
UTC1126 - AP_Vehicle
- https://github.com/ArduPilot/ardupilot/pull/12194
- Appeal from scripting side
- Common interface at the top allows scripting to be at top
- Set_mode interface at the top
- Need to make sure things like the boardconfig stuff still works
- Need to make sure all the boardconfig stuff works
- Relatively small changeset
- Check flash size - fmuv2 before and afterwards
- Lots of testing ideas added down the bottom
- Not the start of a “single binary” project
- Maybe merge next week
UTC1134 - https://github.com/ArduPilot/ardupilot/pull/11870
- WS LEDS
- People have wanted these forever
- WS LEDs
- Tom’s old support for them
- https://www.youtube.com/watch?v=sFSdT5x46SI&feature=youtu.be
- 100 bytes per LED
- 32x16 LEDs supported
- But you don’t have any outputs left. Worth it?
- Scripting support coming
- Fancy patterns based on flight state
- Some tweaks to API required
- Kopis comes with chains of these LEDs
- Chains on helicopter blades
- Bunch of stuff on top of Tom’s patches
- Blheli passthrough working?
UTC1146 - https://github.com/ArduPilot/ardupilot/pull/12180
- Safety LEDs safety buzzer stuff
- Adds a whole bunch of functionality to AP_Periph
- Merge or review required
- Includes the above neopixel stuff
- Set buzzer volume
- Getting reviews is a problem for this low-level stuff
- Tridge is self-reviewing a bunch of stuff
- Relying on his bad memory
- Fix for dynamic node allocator merged
- Vsnprintf didn’t do %llu
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/12087
- Needs more testing
- Tridge wants to know that two connections both doing signing with different GCSs
- Need to make sure replay attacks aren’t possible
- Really need autotest stuff to happen
UTC1155 - https://github.com/ArduPilot/ardupilot/pull/11795
- Randy has looked at it
- Up to tridge to review again
- He’ll need to do extensive testing himself given the first set of tests which went on
- Testing was done prior to the review and was broken during the initial review
- So tridge reviewed broken code
- Bill’s flown it again
- Some perf testing has been done
- Some problems on Pixhawk v1
- Bootloader issue?
- Maybe just the tool from the PX4 repo bailing out?
- Should be available on the f405 boards due to fewer supported sensors
- Pixhawk1 1M board will stop working first
UTC0004 - https://github.com/ArduPilot/ardupilot/pull/10021
- Abort VTOL takeoffs that take too long
- Rebase and we were happy to merge it?
- Can’t actually remember
- merge after deleting the file and passing ci
UTC0010 - Plane update
- release notes for 4.0.0 beta1 to be written
- More changes in Copter than Plane
- Tuning stuff with new loiter controller in quadplane though
- New filtering code
- Affecting people’s tuning
UTC0012 - Copter update
- OA and stay-out zones are still in progress
- https://github.com/ArduPilot/ardupilot/pull/12167
- Inclusion and exclusion zones etc
- Better reporting to the user
- Too many points
- No path
- Etc
- Randy’s been pushing the limit
- 33 stay-out circles and it worked
- MAVProxy changes need to go in
- QGC has a fantastic interface
- Beautiful
- But we need the MAVProxy changes in
- And the Mission Planner stuff
- ::frprintf debugging in threads is very, very nasty
- hal.console->printf might have worked better
- Should we redirect it?
- Debugging symbols are allowed to change which optimisations are done
- A minimal program to reproduce is required the FPE problem
UTC0030 - https://github.com/ArduPilot/ardupilot/pull/12238
- Currently only works on first instance
- Serial0 serial1 etc?
- “Physical serial port 2”?
- Telem2 on a cube?
- Serial2 is just what’s on the case
- One of several different names
- Serial numbers are better than SR parameters
- Serial0 Serial1 Serial2 Serial3
- 0-indexed vs 1-indexed
- PWM channels are 1-based
- Relevant for the LED stuff from earlier
- User-friendly or programmer norms
UTC0042 - Close
