Dev Call Oct 8, 2018 2300 UTC
Issues & Pull Requests
General
  • DShot,
  • Heads-up for possible param reset issue,
  • Access to macos machine for dev team members
Plane Update
Copter Update
Rover Update
Attendee count (max): 21
UTC2307 - https://github.com/ArduPilot/ardupilot/pull/9513
  • Start of scripting support
  • Runs on ChibiOS and Linux
  • Not enabled by default
  • Shows basics of getting started
  • Avoids rebase history and merge conflicts
  • Messing with waf and ChibiOS flags and fixes flags for C files
  • Passing CI
  • Pushed in!
  • Documentation time has already been set aside so it’s usable my mere mortals
  • Please do not fly this code!
  • Waf configure --enable-scripting
  • How about a top-level common object with a zero-length substring?
  • So common vehicle parameters are, in fact, common
    • Need to attack the defines/config thing
    • Means all vehicles get new feature at same time rather than as an afterthought
UTC2308 - https://github.com/ArduPilot/ardupilot/pull/9497
  • Blackmagic micro cinema camera controlled via s.bus
  • Talked with the manufacturer
    • They’re likely to continue to support this on certain cameras for integration with drones etc
  • Aperture control via PWM range etc etc
  • Zoom etc etc
  • Iso
  • “Flip channel” to move between various actions
  • Working using SoloLink
  • Integrated with Solex
  • Uses s.bus out
  • S.bus channels used?
    • Defines on this camera
      • you say channel 8 is for this particular feature
  • Could use with the s.bus-out-on-general-uart code
  • Can also take pwm
    • but only four channels
      • Which is quite limiting
  • Doesn’t quite follow out frontend/backend split
    • Probably OK for the time being
  • Camera split
    • Ap_camera_servo
    • Ap_camera_bmcc etc
  • This is clean enough to go in as-is
  • Just needs our code-style thing run against it
  • Rcin passththrough?
    • In case you don’t have a Solo controller
    • Come back for the rc channel stuff
    • Similar to the eliminate-rcmap stuff Peter’s done
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/9470
  • Adjusting slew rates on Copter
  • Whatever we do here is a compromise
    • Anything going in Philip is really happy with
  • If this works properly you should never need the in-air restart
    • They still fall out of the sky with the existing restart code anyway
  • Getting this in is worthwhile to start with
    • Come back later for the in-air restart
  • Get currently running task expected loop rate from scheduler instead of using dts and counters?
    • Current task number
    • Do you really want a dt?
    • A long-term average is probably what most places want
    • A lot of counters should be dts
    • Some places are doing bodgy integrations
    • [10:29 AM] (Channel) rmackay9: yeah, sometimes you want a dt and sometimes you don’t…
    • [10:30 AM] (Channel) rmackay9: dt and loop rate statics
  • Testing is a problem
    • Needs a parachute on the vehicle, really
    • CLI scripting reproduced and allowed fixes
      • Still happened in-air
    • Try to crowd-source reproduction / fixing?
  • Should run this on non-Solo to see what the performance impact are
  • This apparently also happens on KDE ESCs
  • Leonard can explain the tuning effects of this
  • Long-cable ESC testing on the weekend was illuminating for CanberraUAV
    • Motors failed at 80% throttle
    • 55kHz ripple in PWM value corresponding to switching frequency of ESC
      • Interfering with its own PWM input
    • Ferrites on Solo… ask Jeff…
UTC2336 - https://github.com/ArduPilot/ardupilot/pull/9414
  • AP_BatteryMonitor
    • MdB thinks it’s good to come in
  • Moves arming checks around
  • Peter found a pre-existing behaviour
    • MdB wants to track that separately
    • Don’t need to solve all the world’s problems with this PR
  • Tridge thinks we should fix the graphing tools right now to avoid churn
    • Would break existing graphing tools
    • Leaving it up to MdB as to whether he does the instance stuff or not
UTC2336 - https://github.com/ArduPilot/ardupilot/pull/9391
  • Tridge hasn’t gotten back to this stuff
  • Tridge currently hsa 13 things assigned to him
  • Thanks for the reminder!
UTC2343 - https://github.com/ArduPilot/ardupilot/pull/9381
  • Hexacopter redundancy
  • No Leonard
  • Just needs to do a final test
  • Video Randy did made it look really good
UTC2344 - https://github.com/ArduPilot/ardupilot/pull/9369
  • Merged!
  • The EKF variance thing is interesting….
  • Straight-forward enough
  • Writing tests is getting much, much easier
  • [10:46 AM] (Channel) rmackay9: we discussed this last week…
  • [10:46 AM] (Channel) rmackay9: as long as it passes SITL… I’m happy
  • [10:46 AM] (Channel) rmackay9: I just asked last week that it be tested in SITL… and tha’s been done now…
UTC2347 - https://github.com/ArduPilot/ardupilot/pull/9167
  • Another on tridge’s plate…
    • He’ll get to it…
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/9066
  • Tridge will get to it
UTC2349 - refactoring rangefinder management
UTC2351 - vesca protocol
UTC2353 - more on tridge’s list
  • https://github.com/ArduPilot/ardupilot/pull/8175
  • https://github.com/ArduPilot/ardupilot/pull/7493
    • Related to tricopter yaw issue?
    • Wing twist while transitioning issue?
    • Interesting aerodynamic effects if trying to yaw during transition
      • Late transition as well – MdB
      • And in assist
    • Something in-between level-transition and no-level-transition
      • E.g. constrain height gained in forward transition until we’ve gained some initial speed
        • E.g. down gain 10m of height until we’ve met initial transition speed
          • We met 70m on QuadPorter in the OBC
          • Would have been better if that had been constrained…
        • Possibly same with yaw
    • Tridge needs to PR the timeout change from OBC
      • If you reach half the altitude after a timeout expires then transition
      • You could force landing instead
      • Three airframes in OBC2018 were marginal on climb
      • Even a small amount of forward speed helps
        • Different power sources for vertical/horizontal really, really helps
        • Single battery for both can be very, very bad
          • Tridge has seen 2.5V/cell
          • ESCs can hit their low-voltage cut-out and then the aircraft is dead
  • On tridge’s plate….
UTC0001 - d-shot param reset
  • Serious bug
  • Missing lock in d-shot code
  • Simple to fix
  • One user had a reproducible case
    • Lockup after 10 seconds
    • Particular parameter set
  • 3.9.2 will be going out shortly with this fix in it
  • Copter rc is already out with fix in it
    • Rc12
  • Had potential to cause crash
    • Not sure it ever did, however
UTC0002 - Reverse-throttle with d-shot is coming
  • Reverse-thrust landings initially
  • Copter fun-and-games after that
UTC0003 - virtual MacOS machine
  • Thanks to funding committee for approving this!
  • Grant has also given tridge a MacMini
    • If anyone wants remote access poke tridge
  • Really just to make sure the dev tools work OK
  • Tridge’s OS is quite recent
  • Jani thinks many people are using older OSs
UTC0005 - Plane update
  • Iampete’s stuff probably won’t go into 3.9.2
    • But 3.9.3
  • Some pending changes for some boards may go in
  • Testers for new IO firmware would be appreciated!
    • Much done in last week with thanks to Sid
  • Servo voltage reporting doesn’t work
  • S.bus output doesn’t work
  • Mixer stuff doesn’t work in current stuff anyway
  • Safety ignore stuff should all be correct
  • Testing on Rover would be appreciated
    • Rc input servo output
    • One-shot
    • Peter can help test here
    • Latency of one-shot needs to be tested
  • Navio2 will also need testing
    • Uart-connected
    • Luis was volunteered
    • Navio+
      • I2c to pwm chip
      • But MdB has some stuff he’d like tested on this
  • Raspilot too
UTC0015 - Copter and Rover updates
  • Randy has no audio and is between trains…
UTC0016 - upcoming conference
  • Good luck!
UTC0016 - talking with CMAC about conference next year
  • Any thoughts on dates, please ping tridge soon
  • Avoid the hot Sunday thing
    • A little later in the year this time
    • Late March, early April
FF: Did you say late March/early April?
[11:17 AM] (Channel) CB: Avoid school holiday :slight_smile:
[11:17 AM] (Channel) MdB: Do you have a propsal into build in a pool for swimming and boat testing? :smiley:
[11:17 AM] (Channel) FF: I’ll likely be travelling. Not sure I can make it anyway
  • Concentrate on sailing boats?
  • There’s an airshow around that time that might be good to be close to
    • Avalon airshow
