opened 03:45AM - 13 Mar 23 UTC
DevCallTopic
ReleaseAdmin
This is a list of issues discovered during Copter and Rover 4.4 testing. The ol…der [4.3 issues list can be found here](https://github.com/ArduPilot/ardupilot/issues/21711).
Reports requiring investigation:
- [ ] MAVFTP (using MP) of terrain data to SD card takes 25min ([discussion](https://discuss.ardupilot.org/t/terrain-data-loading-on-sd-card-via-mavftp-is-slow/107750))
- [ ] CRSF option for "RX Battery Sensor" sends telem that conflicts with Yaapu telem (?) ([discussion](https://discuss.ardupilot.org/t/copter-4-4-1-beta1-available-for-beta-testing/106076/12))
- [ ] TKOFF_THR_MAX not actually included in release ([discussion](https://discuss.ardupilot.org/t/copter-4-4-1-released/107005/3))
- [ ] RCIn scaled not working? ([discussion](https://discuss.ardupilot.org/t/release-rover-4-4-as-stable-ok/106080/6))
- [ ] EKF3 external nav is fusing using wrong GPS noise ([issue](https://github.com/ArduPilot/ardupilot/issues/24020))
- [ ] benewake TFminiPlus-I2C timing out with NoData ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-released/105233/56))
- [ ] Lane switching warning (reported by Partner, [issue](https://github.com/ArduPilot/ardupilot/issues/24181))
- [ ] MSP on Matek board ([discussion](https://discuss.ardupilot.org/t/msp-problem-no-gps-comp-and-baro-data/103043))
- [ ] CSRF and Mount Siyi boot loop ([see bottom of this issue](https://github.com/ArduPilot/ardupilot/issues/23815))
- [ ] very short ELRS failsafes ([issue](https://github.com/ArduPilot/ardupilot/issues/23853), [PR](https://github.com/ArduPilot/ardupilot/pull/24170))
- [ ] endless climb with vertical bendy ruler? ([discussion](https://discuss.ardupilot.org/t/rtl-and-auto-mode-working-in-strange-mode/100132/4))
- [ ] Baro TCal not working? ([issue](https://github.com/ArduPilot/ardupilot/issues/21438))
- [ ] EKF error on small quad ([reported by MichelleR](https://github.com/ArduPilot/ardupilot/issues/23594), [PR may help](https://github.com/ArduPilot/ardupilot/pull/24135))
Confirmed issues:
- [ ] Gremsy ZIO zoom and focus not working? ([discussion](https://discuss.ardupilot.org/t/gremsy-zio-mavlink-commands-not-working/103080)) -- needs backport from 4.5
- [ ] GSF on Rover not working below 5m/s ([discussion](https://discuss.ardupilot.org/t/yaw-not-aligning-to-gsf-anymore-after-updating-from-4-2-3-to-4-4-0-beta1/101844/2), [related PR](https://github.com/ArduPilot/ardupilot/pull/23515), [issue](https://github.com/ArduPilot/ardupilot/issues/24183), [PR](https://github.com/ArduPilot/ardupilot/pull/24206))
- [ ] KDECAN not working ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta2-available-for-beta-testing/102158/11)) -- needs backport from 4.5.
- [ ] Yaapu reports battery 2 error but only one battery is installed ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta1-available-for-beta-testing/99941/7))
Enhancements or Issues that may not be resolved before the stable release:
- [ ] Provide RemoteID support firmware to ease setup ([issue](https://github.com/ArduPilot/ardupilot/issues/24789), [discussion](https://discuss.ardupilot.org/t/offical-copter-release-with-remote-id-support/105543))
- [ ] ADSB on AP_Periph support? ([discussion](https://discuss.ardupilot.org/t/adsb-using-ap-periph-not-connecting/105634), [wiki](https://github.com/ArduPilot/ardupilot/blob/master/Tools/AP_Periph/README.md), [issue](https://github.com/ArduPilot/ardupilot/issues/24802))
- [ ] Terrain alt clamping can lead to failed takeoff and flip on takeoff in Auto (reported by rmackay9)
- [ ] Enable 10hz PID logging
- [ ] RPLidarA2M12 not working ([discussion](https://discuss.ardupilot.org/t/rp-lidar-a3-integration-with-ardupilot/101792/11))
- [ ] Auto mode yaw changes slightly even if WP_YAW_BEHAVE = 0 ([issue](https://github.com/ArduPilot/ardupilot/issues/23782))
Resolved issues:
- [x] users keep forgetting to set CAM1_TYPE (or CAM_TRIGG_TYPE) ([discussion](https://discuss.ardupilot.org/t/mav-cmd-set-camera-zoom-command-doesnt-work/100613/4)) -- fewer reports recently perhaps because of wiki updates
- [x] RockBlock only works with MAVProxy ([discussion](https://discuss.ardupilot.org/t/rockblock-iridium-sbd-and-mission-planner/102728), [wiki PR](https://github.com/ArduPilot/ardupilot_wiki/pull/5263)) -- Stephen Dade will raise wiki and MP/QGC issues -- added to wiki for -beta4
- [x] yaw reset from low flying copter passing over bridge (Randy has logs) -- older version of AP, new versions should be a little better
- [x] Request to add Custom Build Server support for beta builds ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta2-available-for-beta-testing/102158/7), [issue](https://github.com/ArduPilot/CustomBuild/issues/54, [PR](https://github.com/ArduPilot/CustomBuild/pull/55))) -- resolved for -beta3
- [x] Gremsy WE not working ([4.4 discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta1-available-for-beta-testing/99941/15), [4.3.7 discussion](https://discuss.ardupilot.org/t/gremsy-pixy-we-not-working-with-4-3-5/99163)) -- Gremsy software issue. Fix from Gremsy coming soon
- [x] Siyi A8 ROI not working (reported by Kelly Schrock on facebook, [discussion](https://discuss.ardupilot.org/t/siyi-a8-roi-issue/102091), [PR](https://github.com/ArduPilot/ardupilot/pull/24011)) -- resolved for -beta3
- [x] MatekF405-TE-bdshot only 2 channels working (see Painless360's channel) -- user error
- [x] FPV406 watchdog due to cracked SD card ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta1-available-for-beta-testing/99941/48)) -- no logs
- [x] Mount serial gimbal param description confusion ([discussion](https://discuss.ardupilot.org/t/ip-cameras-rtsp-mavlink-support/99893/20)) -- fixed for beta3
- [x] serial pass through (for GPS) broken ([issue](https://github.com/ArduPilot/ardupilot/issues/21114), [PR](https://github.com/ArduPilot/ardupilot/pull/23888)) -- fixed in -beta2
- [x] RC loss+regain issue ([PR](https://github.com/ArduPilot/ardupilot/pull/23844)) -- fixed in -beta2
- [x] MP scales set-ekf-origin-here altitude incorrectly ([MP issue](https://github.com/ArduPilot/MissionPlanner/issues/3083)) -- fixed in MP 1.3.80 build 1.3.8522.19145
- [x] Custom build server broken for Matek405 builds ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta1-available-for-beta-testing/99941/13))
- [x] CubeOrangePlus not booting due to early memory corruption (reported by rmackay9, investigated by Tridge, PeterB, Sid)
- [x] RTL_SPEED does not work if WPNAV_SPEED adjusted (reported by lthall, [PR](https://github.com/ArduPilot/ardupilot/pull/23553))
- [x] Watchdog using CSRF ([discussion](https://discuss.ardupilot.org/t/copter-4-4-0-beta1-available-for-beta-testing/99941/18), [PR](https://github.com/ArduPilot/ardupilot/pull/23648)) -- resolved for beta2
