Dev Call Oct 23, 2023
Issues & Pull Requests
Plane
Copter
Attendee count (max): 17
UTC2300 - Generator: Lua: allow strings by IamPete1 · Pull Request #868 · ArduPilot/pymavlink · GitHub
  • Pymavlink generator - allow strings
  • Merged!
UTC2303 - AP_HAL_ChibiOS: Add UART7 to RADIX2HD target by mluessi · Pull Request #24485 · ArduPilot/ardupilot · GitHub
  • Add UART7 to RADIX2HD
  • We don’t need both pins on the uart
  • Merged!
UTC2306 - Plane: Allow a ICE start even if disable while disarmed is set by WickedShell · Pull Request #25138 · ArduPilot/ardupilot · GitHub
  • Allow ICE to start even if disable is set
  • MergeOnCIPass
UTC2310 - Rover: implement external control by srmainwaring · Pull Request #25204 · ArduPilot/ardupilot · GitHub
  • Implement external control for Rover
  • MergeOnCIPass
UTC2315 - AP_Scripting: Add examples for RangeFinder filter by rishabsingh3003 · Pull Request #25217 · ArduPilot/ardupilot · GitHub
  • Add examples for rangefinder filter
  • Flaw with a 5-second pause in case no readings received
UTC2324 - AP_AHRS: ensure we check health of the sensor we are using. by IamPete1 · Pull Request #25272 · ArduPilot/ardupilot · GitHub
  • Check health of same sensor we were using
  • May be a problem with affinity
  • Might have a slight circular-reasoning problem
    • PH will remove some changes which cause that question
UTC2335 - AP_RangeFinder: Add new driver for TOFSense F I2C by rishabsingh3003 · Pull Request #25268 · ArduPilot/ardupilot · GitHub
  • Add tofsense i2c
  • MergeOnCIPass
UTC2337 - Plane: send attitude target message implementation (for quadplanes) by miodine · Pull Request #25286 · ArduPilot/ardupilot · GitHub
  • send attitude target message on quadplane
  • MergeOnCIPass
UTC2339 - AP_TECS: log SKE weight since both weights are now [0,1] by magate · Pull Request #25287 · ArduPilot/ardupilot · GitHub
  • Log SKE weight since both weights are now [0,1]
  • Merged!
  • Also added docs for TEC2
UTC2344 - AP_HAL_ChibiOS: RADIX2HD Probe external I2C compasses by mluessi · Pull Request #25291 · ArduPilot/ardupilot · GitHub
  • Probe external i2c compasses on RADIX2HD
  • Merged
UTC2346 - Handle MAV_CMD_NAV_TAKEOFF as both command-long and command-int by peterbarker · Pull Request #25299 · ArduPilot/ardupilot · GitHub
  • Handle MAV_CMD_NAV_TAKEOFF as both command-long and command-int
  • Spoke with Hamish and we thought MAV_FRAME_GLOBAL_VEHICLE_ALT as a new frame
  • MAV_FRAME_GLOBAL_VEHICLE_RELATIVE_ALT
UTC0014 - Remove handling of PREFLIGHT_SET_SENSOR_OFFSETS by peterbarker · Pull Request #25305 · ArduPilot/ardupilot · GitHub
  • SET_SENSOR_OFFSETS
  • 11:09 AM]WickedShell: MAV_FRAME_GLOBAL_VEHICLE_RELATIVE_ALT (edited) [
  • If QGC is broken then we remove this code rather than handle it as command
  • Just tested, delete old code
UTC0036 - Handle MAV_CMD_DO_FENCE_ENABLE as both long and int by peterbarker · Pull Request #25307 · ArduPilot/ardupilot · GitHub
  • Do_fence_enable as both long and int
  • merged!
UTC0037 - Allow PayloadPlace to be compiled out, factor same by peterbarker · Pull Request #25310 · ArduPilot/ardupilot · GitHub
  • Slight refactor for payload place
  • Can be merged once it is added to build_options and extract_features
UTC0043 - BETAFPV F405 fixes by andyp1per · Pull Request #25314 · ArduPilot/ardupilot · GitHub
  • Betafpv f405 fixes
  • Fixes IMU orientation
  • Merged!
UTC0045 - Plane: Mode LoiterAltQLand to reuse same loiter point if available by magicrub · Pull Request #25318 · ArduPilot/ardupilot · GitHub
  • Don’t make new loiter circle if we are already loitering
    • Could be problematic if you’re notionally circling but actually traversing to somewhere
UTC0048 - Plane: mode LoiterAltQLand to use QRTL by magicrub · Pull Request #25319 · ArduPilot/ardupilot · GitHub
  • LoiterAltQLand to use QRTL
  • Loiter-to-alt then qland means you stop somewhere random on the circle
  • After a right-click, “land here” to GCS interfaces
  • Some sort of mode for “land right here”?
  • Use DO_REPOSITION?
  • Reuse the existing RTL behaviour but with a different location
    • E.g. using qrtl stuff
UTC0112 - Handle PREFLIGHT_SET_SENSOR_OFFSETS as both long and int by peterbarker · Pull Request #25305 · ArduPilot/ardupilot · GitHub
  • Remove set-sensor-offsets
  • MergeOnCIPass
UTC0114 - waf: remove SKETCHBOOK define by tridge · Pull Request #25320 · ArduPilot/ardupilot · GitHub
  • Remove build path
  • MergeOnCIPass
UTC0117 - hwdef:include minimal in minimize_common by Hwurzburg · Pull Request #25328 · ArduPilot/ardupilot · GitHub
  • Minimal in minimize_common
  • Makes many boards more regular
  • Henry is fixing all the yellow boards too
UTC0121 - AP_Compass: add big comment explaining calculate_heading by IamPete1 · Pull Request #25336 · ArduPilot/ardupilot · GitHub
  • Add a big comment explaining calculate_heading
  • And tidy it a chunk
  • Merged!
UTC0124 - Make it possible to surrpress the status text on arming/disarming the aircraft. by WickedShell · Pull Request #25345 · ArduPilot/ardupilot · GitHub
  • Suppress status text message on arm/disarm
  • MergeOnCIPass
UTC0130 - Plane update
  • 42688 gyro stuck bug found and fixed with help from TDK
  • 4.4.3 coming with this and some more fixes
UTC0131 - Copter update
  • Copter release was done
UTC0131 - off the floor
  • DevTeam please check funding option vote concept
