CraigElder
(Craig Elder)
2
Attendee count (max): 20
- Ask James for which way we should move forwards
- Also include speedup vs wallclock time?
- Tridge is happy either way
- Either adding altitude velocities to ours and quat to ours
- Remove warning mechanism for things in features.txt but not in build options
- Henry would prefer to keep the warnings
- Peter will add a hidden option to the build features
- Random values in battery status message if pin is -1
- Needs to be chased down
- OpticalFlow in Rover
- Is optical flow being fused without rangefinder?
- That would be bad
- Randy will check Copter
- Scripting log allocation fix
- Merged
- Manual leak detector pin
- Willian will test
- Added AUTOTUNE_AXES function to normal tune
- Merged!
- Remove NCP from code with explicit define rather than minimize features
- Merged!
- Fixes to get examples to run with logging
- Better fix to do something in boards.py
- Peter will extract the fence patch
- Helpers for full-range variables in AP_Scripting
- Tridge wants integer wrapping
- Tridge doesn’t like range checks
- Doesn’t like scripts dying on the range checks
- E.g. gps doesn’t come up and a script dies rather than getting nil back
- Synthetic current sensor
- Where to put parameters?
- New inherited backend
- Defines fixes
- Peter to check no change on l431 bootloader
- More defines fixes for HOTT and …
- Merged!
- Fixes for CAN GPSs / RTK fixes
- Sid to look at
- Disable GPS lag checking in AP_Periph
- Periph gps was marking itself unhealthy when the flight controller could have worked out exactly the same thing
- Maybe just remove this entire block of code?
- We separately check update rates so maybe rely on it?
UTC0039 - RemoteID update
- Several PRs have gone in
- Another release out today probably
- Craig’s testing is going well
UTC0041 - Plane update
- One problem report to look at
- 4.3.2 pending PR list isn’t empty
- Throttle governor when disarmed
- ICE engines operator want to start engine disarmed
- Throttle governor should be fully active
- Only active in some flight modes etc
- Want it active in several
- Safety thing
- Hand-held starter when vehicle is armed is bad
- Proposed changes won’t allow it to above idle
- CRSF still needs the three-frame change
UTC0041 - Copter update
- Not many reports on 4.3.0
- Please report if you’re having problems
- Lucas found problem with SkyViper
- download/update-firmware/upload parameters have caused some issues
- Benewake H30?
- Not released by Benewake yet?
Driver might need renaming
- Gimbal support
- Gremsy being overloaded with high update rates
- Driver sending attitude too fast
- STorm32 mavlink driver user states changing gimbal pitch that the vehicle’s yaw was changing
- QGC does allow gimbal to be controlled
- QGC joystick setup page
- Functions to buttons
- One function to allow you to control gimbal pitch
- Maintains a target attitude internally
- Send mount control message to ArduPilot
- Sends yaw angle as zero?!
- No way to ignore fields
- So it points the vehicle North
- Change QGC to not use the mount control issue
- Setup screens aren’t working in either MP or QGC
- Servo gimbals are not working correctly
- Not pointing at target properly
- Calculations need tightening up
- Will only use roll servo to correct vehicle orientation
UTC0101 - Rover update
- Balancebot issues….
- shakier?
- Randy’s been assuming wheel encoder noise
- Maybe tuning or filtering changes?
- 4.3.0 out in a few days regardless of BB outcomes
UTC0103 - Plane acrobatics is a thing
- Tridge would like testers
- Join the thread!
UTC0104 - Conference
- Add yourself to the spreadsheet…
- If you want travel funding assistance then contact the funding team
UTC0104 - close
