# Purpose
This fixes numerous omitted steps that resulted in failed default b…ehavior and replaces #61.
## Issues fixed
* No remote upstream added
* No requests library installed
* Converted from manual python deps install to a `requirements.txt` file (standard python practice)
* Added terminal commands to make it easier for ubuntu devs to get started with the custom build server
* spelling
* no syntax highlighting for bash commands
## Logs
Here is one failure, because the user never added `upstream` as a remote or fetched it:
$ ./app.py
[2023-11-25 11:54:07,195] INFO in app: Creating /home/ryan/Dev/ros2_ws/src/base/builds
[2023-11-25 11:54:07,195] INFO in app: Got queue lock
[2023-11-25 11:54:07,221] INFO in app: Initial fetch
[2023-11-25 11:54:07,221] INFO in app: Running git rev-parse upstream/master in /home/ryan/Dev/ros2_ws/src/base/ardupilot
fatal: ambiguous argument 'upstream/master': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions, like this:
'git <command> [<revision>...] -- [<file>...]'
Traceback (most recent call last):
File "/home/ryan/Dev/ros2_ws/src/CustomBuild/./app.py", line 544, in <module>
checkout_branch(get_default_branch_name(), s_dir=sourcedir, fetch_and_reset=True)
File "/home/ryan/Dev/ros2_ws/src/CustomBuild/./app.py", line 144, in checkout_branch
if not on_branch(targetBranch):
File "/home/ryan/Dev/ros2_ws/src/CustomBuild/./app.py", line 127, in on_branch
git_hash_target = get_git_hash(branch)
File "/home/ryan/Dev/ros2_ws/src/CustomBuild/./app.py", line 124, in get_git_hash
return subprocess.check_output(['git', 'rev-parse', branch], cwd=sourcedir, encoding='utf-8', shell=False).rstrip()
File "/usr/lib/python3.10/subprocess.py", line 421, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['git', 'rev-parse', 'upstream/master']' returned non-zero exit status 128.
Another failure, the dev was never told to install requests.
$ ./app.py
/home/ryan/Dev/ros2_ws/src/CustomBuild/./app.py:13: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.dir_util import copy_tree
File "/home/ryan/Dev/ros2_ws/src/CustomBuild/./app.py", line 18, in <module>
import requests
ModuleNotFoundError: No module named 'requests
After this change, the following behavior is now correct:
$ ./app.py
[2023-11-25 12:01:57,252] INFO in app: Got queue lock
[2023-11-25 12:01:57,252] INFO in app: Initial fetch
[2023-11-25 12:01:57,252] INFO in app: Running 'git rev-parse upstream/master' in /home/ryan/Dev/ros2_ws/src/base/ardupilot
[2023-11-25 12:01:57,254] INFO in app: Expected branch git-hash 'ea237724c772a0dd5ec3c30dba3f3eca5c49f46a'
[2023-11-25 12:01:57,254] INFO in app: Running 'git rev-parse HEAD' in /home/ryan/Dev/ros2_ws/src/base/ardupilot
[2023-11-25 12:01:57,256] INFO in app: Current branch git-hash 'ea237724c772a0dd5ec3c30dba3f3eca5c49f46a'
[2023-11-25 12:01:57,256] INFO in app: Running git: git fetch upstream
[2023-11-25 12:01:58,617] INFO in app: Running git: git reset --hard upstream/master
HEAD is now at ea237724 Tools: autotest: Fix junit printing for double str
[2023-11-25 12:01:58,639] INFO in app: Running 'git rev-parse HEAD' in /home/ryan/Dev/ros2_ws/src/base/ardupilot
[2023-11-25 12:01:58,641] INFO in app: Updating submodules
[2023-11-25 12:01:58,641] INFO in app: Running git: git submodule update --recursive --force --init
Submodule 'modules/ChibiOS' (https://github.com/ArduPilot/ChibiOS.git) registered for path 'modules/ChibiOS'
Submodule 'modules/CrashDebug' (https://github.com/ardupilot/CrashDebug) registered for path 'modules/CrashDebug'
Submodule 'modules/DroneCAN/DSDL' (https://github.com/DroneCAN/DSDL.git) registered for path 'modules/DroneCAN/DSDL'
Submodule 'modules/DroneCAN/dronecan_dsdlc' (https://github.com/DroneCAN/dronecan_dsdlc) registered for path 'modules/DroneCAN/dronecan_dsdlc'
Submodule 'modules/DroneCAN/libcanard' (https://github.com/DroneCAN/libcanard) registered for path 'modules/DroneCAN/libcanard'
Submodule 'modules/DroneCAN/pydronecan' (https://github.com/DroneCAN/pydronecan) registered for path 'modules/DroneCAN/pydronecan'
Submodule 'modules/Micro-CDR' (https://github.com/ardupilot/Micro-CDR.git) registered for path 'modules/Micro-CDR'
Submodule 'modules/Micro-XRCE-DDS-Client' (https://github.com/ardupilot/Micro-XRCE-DDS-Client.git) registered for path 'modules/Micro-XRCE-DDS-Client'
Submodule 'modules/gbenchmark' (https://github.com/google/benchmark.git) registered for path 'modules/gbenchmark'
Submodule 'modules/gsoap' (https://github.com/ArduPilot/gsoap) registered for path 'modules/gsoap'
Submodule 'gtest' (https://github.com/ArduPilot/googletest) registered for path 'modules/gtest'
Submodule 'modules/mavlink' (https://github.com/ArduPilot/mavlink) registered for path 'modules/mavlink'
Submodule 'modules/waf' (https://github.com/ArduPilot/waf.git) registered for path 'modules/waf'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/ChibiOS'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/CrashDebug'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/DroneCAN/DSDL'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/DroneCAN/dronecan_dsdlc'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/DroneCAN/libcanard'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/DroneCAN/pydronecan'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/Micro-CDR'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/Micro-XRCE-DDS-Client'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/gbenchmark'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/gsoap'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/gtest'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/mavlink'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/waf'...
Submodule path 'modules/ChibiOS': checked out '3ef1657d53e643aa61f7268ab4b8596bf6826fdb'
Submodule 'ext/lwip' (https://github.com/ArduPilot/lwip.git) registered for path 'modules/ChibiOS/ext/lwip'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/ChibiOS/ext/lwip'...
Submodule path 'modules/ChibiOS/ext/lwip': checked out '6ca936f6b588cee702c638eee75c2436e6cf75de'
Submodule path 'modules/CrashDebug': checked out '599965086437137ec0fe66e185611f43f335f889'
Submodule 'CrashCatcher' (https://github.com/ardupilot/CrashCatcher.git) registered for path 'modules/CrashDebug/CrashCatcher'
Submodule 'mri' (https://github.com/ardupilot/mri.git) registered for path 'modules/CrashDebug/mri'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/CrashDebug/CrashCatcher'...
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/CrashDebug/mri'...
Submodule path 'modules/CrashDebug/CrashCatcher': checked out '4cf6e11df3a081b0f573a7834ed8e1e4000af73e'
Submodule 'CppUTest' (https://github.com/ardupilot/CppUTest.git) registered for path 'modules/CrashDebug/CrashCatcher/CppUTest'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/CrashDebug/CrashCatcher/CppUTest'...
Submodule path 'modules/CrashDebug/CrashCatcher/CppUTest': checked out '011f371fdb5d7e441fb023be67295783e053df4a'
Submodule path 'modules/CrashDebug/mri': checked out 'b35c89451b41a45b7f5b580acaff555315ac88e2'
Submodule 'CppUTest' (https://github.com/ardupilot/CppUTest.git) registered for path 'modules/CrashDebug/mri/CppUTest'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/CrashDebug/mri/CppUTest'...
Submodule path 'modules/CrashDebug/mri/CppUTest': checked out '011f371fdb5d7e441fb023be67295783e053df4a'
Submodule path 'modules/DroneCAN/DSDL': checked out 'de93d9c8bb76de1b093050e3a31e4d4ce539c577'
Submodule path 'modules/DroneCAN/dronecan_dsdlc': checked out 'ebaf96860a11a4cc43c01df6b651df143c6cde2d'
Submodule path 'modules/DroneCAN/libcanard': checked out '22102c717db29cc2a2c2869ff80f3e4389704d89'
Submodule 'drivers/avr/avr-can-lib' (https://github.com/rennerm/avr-can-lib) registered for path 'modules/DroneCAN/libcanard/drivers/avr/avr-can-lib'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/DroneCAN/libcanard/drivers/avr/avr-can-lib'...
Submodule path 'modules/DroneCAN/libcanard/drivers/avr/avr-can-lib': checked out '9c6bc9118de66d6edaf1b8539e2b9717ba26d123'
Submodule path 'modules/DroneCAN/pydronecan': checked out '19fdf2e5b383243ccdb1094edae0603cf11469e8'
Submodule path 'modules/Micro-CDR': checked out '3d1b17703c7cf4f22def2910bc845bdb5152d7b5'
Submodule path 'modules/Micro-XRCE-DDS-Client': checked out '97175304425c5bee87c6fddd99de1ef8d0c394dc'
Submodule path 'modules/gbenchmark': checked out 'd572f4777349d43653b21d6c2fc63020ab326db2'
Submodule path 'modules/gsoap': checked out 'e1f690585d4803402584962bfaa8240ecaf1db30'
Submodule path 'modules/gtest': checked out 'c5fed93f941865a0e912e9baf46ded713506590a'
Submodule path 'modules/mavlink': checked out 'dccd8555cd601467dc793ea9abf85caa63c0a9e8'
Submodule 'pymavlink' (https://github.com/ArduPilot/pymavlink.git) registered for path 'modules/mavlink/pymavlink'
Cloning into '/home/ryan/Dev/ros2_ws/src/base/ardupilot/modules/mavlink/pymavlink'...
Submodule path 'modules/mavlink/pymavlink': checked out '19e385ccb4b6cbe2d08a8689dfcc586389fe14ce'
Submodule path 'modules/waf': checked out '1b1625b8e7da6e1307d73335cb995fa8813d5950'
[2023-11-25 12:02:54,747] INFO in app: Python version is: 3.10.12 (main, Jun 11 2023, 05:26:28) [GCC 11.4.0]
* Serving Flask app 'app'
* Debug mode: off
[2023-11-25 12:02:54,749] INFO in _internal: WARNING: This is a development server. Do not use it in a production deployment. Use a production WSGI server instead.
* Running on http://127.0.0.1:5000
[2023-11-25 12:02:54,749] INFO in _internal: Press CTRL+C to quit
