Dev Call Nov 27, 2017 2300 UTC
Copter
  • 3.5.4 released
Rover
  • 3.2 update
Log analysis
http://www.maverick.one/analysis/uploader/
Issues & PRs
FAA’s UAS integration program
  • Registering as an interested party
Contribution of the month
  • Eligibility
Funding Committee
  • Unconference
Code Of Conduct
Attendee count (max): 22
UTC23:02 - Log analysis / James
  • Maverick is available and people should give it a try and provide feedback
  • Pre-alpha version
  • A few limits on log-size that can be uploaded
  • Tridge needs to talk to Dronee about their Javascript stuff again
  • Perhaps this will work well with
[b]UTC23:04 - [url=https://github.com/ArduPilot/ardupilot/pull/7291]
  • Set a variable in existing switch statement
  • Don’t generate all the names - too much wasted space
  • “Executing wp=%u %s”
UTC23:14 - Randy and Copter and Rover
  • 3.5.4 was out last Thursday
  • Compass fixes
  • See release notes
  • HMC compass GPS modules going away is less of a problem now!
  • Will need a new release of Rover for new GPS stuff
  • Also a Plane release, probably soonish
  • New loiter is progressing
  • Flight-mode-classes
  • Focussing on getting a Rover release out
  • New version is better than the stable version
  • Need to get it out
  • Motor jump when you are rotating on the spot with a skid-steering vehicle and you go from forward to reverse or reverse to forward
  • High left-motor value vs high right-motor value
  • Mixer changes were possibly better the first way
  • Reverting a few bits
  • Should skid-steering vehicles drive like a car?
  • When you drop in reverse….
  • Set_global_position ROS changes
  • Manual mode / steering mode
  • Like driving in auto mode
  • Lateral acceleration etc etc
  • We have other things we could do, ‘though
  • E.g. rotate at 90 degrees/second when holding stick all the way over
  • E.g. headless mode
  • E.g. cruise mode
  • When you activate the sticks it moves a waypoint around (in Plane)
  • Would be useful for boats
  • Yaw’s been fixed for this
  • Guided is already a heading controller….
  • Define size of tires and vehicle length?
  • Maybe all tuning parameters would work after that?
  • Maybe a max steering angle
  • Might need to know more about the steering system
  • Rovers have a very direct line between these parameters and its handling
  • E.g. Wide vehicle with small wheels has slow rotation
  • Halve the vehicle width and turn rate doubles
  • Model-based controller…
  • PR in next couple of days to add this stuff
  • Pierre: small-speed issues need looking at
  • Sometimes the EKF is saying we’re moving slowly backwards when we’re moving slowly fowards….
  • Perhaps an epsilon for speed?
  • Leonard thinks we should rely more on our desired vs our actual speed
  • Trust lower-level controllers to actually get us to that speed
  • Pierre: Ability to add different frames in ROS is coming
[b]UTC23:34 - [url=https://github.com/ArduPilot/ardupilot/pull/7270]
  • S.BUS out PR
  • Should be much safer to merge now
  • Flight-tested now
  • Servos on boot is a problem
  • Setting initial mode to qstabilize seems to work around that
  • SERVO_SBUS_RATE
  • Refresh rates need to be higher to be able to use on multirotors
  • Doing a good job on the Convergence, however!
  • Unbuffered writes will be useful for other systems
  • E.g. the volz servo
  • Jitter goes down a long way
  • 300us now
  • There’s some Log_Writes under SITL
  • Couple of debug statements to go away
  • Tridge will need to look at in-depth
  • UART Pid-restriction needs to be looked at
  • Maybe a semaphore
  • Use early-returns rather than deeply nesting if blocks…
[b]UTC23:48 - [url=https://github.com/ArduPilot/ardupilot/pull/6406]
  • Continue land on failsafe
  • If vehicle is in land mode, should it continue to land if a failsafe activates?
  • Originally this PR changed behaviour with no parameter
  • Parameter now which specifies behaviour
  • No default change in behaviour
  • If param is set then vehicle may continue
  • Should we have a bitmask here?
  • Volume of parameters is a bit painful…
  • Mission Planner’s bitmask interface needs improvement
  • See APWeb’s bitmask interface with checkboxes
  • FS_OPTIONS
  • See Q_OPTIONS
  • Started off with a single bit but within 2 days it was three bits
  • We only ever have one level of failsafe ATM
  • Perhaps we could have multiple levels of failsafe?
  • Land mode is both a mode and an intent
  • E.g. if you are using correction data from a GCS (landing on a ship) then you may not want to continue landing on GCS failsafe!
  • E.g. some people use land to just lose height rather than to actually land
  • Land-within-auto needs to be checked and considered
UTC00:05 - Airspeed driver
  • External baro and airspeed baro on same address
  • Airspeed pin parameter to disambiguate?
  • This is why we added the airspeed_bus parameter
  • But they’re on the same bus
  • Need to change the address on 5525
  • Can we do that?
  • We test for both addresses ATM
  • Add new type ms5525 on alternate address
  • Changes probe address
  • Ms5525-high and ms5525-low?
  • MS5525, MS5525-[hi-addr], MS5525-[low-addr]
UTC00:09 - battery monitors
  • Enable parameters make sense
  • People want more battery monitors
  • Lots of people have power bricks and don’t configure them
  • Type an enable parameter?
  • On by default?
  • Would break the MP setup page if we were to change this behaviour
  • Failsafe may engage by default?
  • All power bricks have different scaling factors
  • Voltage-scaling on motors!
  • Need to do scaling on correct battery pack for quadplanes
  • Trim_throttle in normal planes hsould be scaled with battery voltage
  • Not an issue if you have an airspeed sensor
  • Teach AP_Param to teach the first open to display?
  • Magic flag
  • Sounds complicated
  • Tridge: “parameter library isn’t that scary”
[b]UTC00:17 - [url=https://discuss.ardupilot.org/t/use-apds-9930-proximity-sensor-for-land-detection/23487]
  • really , just be aware of it
UTC00:17 - sensorhub
  • Doesn’t work well with the singleton
  • Instantiates multiple copies
  • Needs to generate the protocols separately from the sensor
  • Pierre wants to use this to test electronics
  • [url=https://github.com/ArduPilot/ardupilot/pull/6388]
  • Using SITL to test more hardware
  • We already have ways of getting data from physical devices
UTC00:23 - regulation
  • This morning the FAA had some webinars to get people to register for their UAS integration program
  • We can register as an interested party
  • Important because US scheme will probably be model for other countries
  • Jeff is willing to take the lead on this
  • Spektreworks, Aion robotics and a few other partners have already registered
UTC00:28 - Contribution of the Month
  • eligibility
  • Maintainers are excluded?
  • Dev-team-members are excluded?
  • Apparently we forgot to put Paul R on the dev-team until yesterday!
  • Welcome to the dev-team Paul!
  • Tridge: Nomination for lorbass for RealFlight modelling
  • Olivier: Nomination Patrick P for helping users on forums etc
UTC00:40 - Volunteers required for funding committee
  • Term has ended
  • People need to step forward if they want to do this
  • We now have three new people! (Olivier, David, Luis)
  • Make funding requests for unconference
  • Clarify FF’s funding term!
  • Vote was for one year discussion was for 6 months
  • Also, please contribute on US$ vs Euro discussion
UTC00:50 - Code of Conduct
  • Prevent member of dev team in own consulting activity working on weaponised/manned aircraft
  • Do good as opposed to weaponising which by definition is intended to do hard
  • How does AP ever get better at manned stuff if we absolutely decree you can’t work with AP on manned?
UTC01:25 No-fly zones
  • At current state we could be excluded
  • Not even close at the moment
  • How about vehicles without GPS?
  • Time frame?
  • Force-down?
  • MISSION_AUTHORIZATION?
  • Or have GCS upload a set of no-fly zones
  • Couple of weeks work
  • Tom did some of this for Syria uplift
  • Randy can do the flight control stuff
  • Need low-level SD-card database storage stuff
  • Authorized zones instead?
  • Authorized areas within no-fly zones?
  • Really has to be done on the flight controller
  • Not CC or GCS
  • DJI is almost real-time
  • updates maps in real-time
  • Bypass codes. Bleh.
  • Multiple tools, we should do many
  • So do MISSION_AUTHORIZATION
  • AND no-fly zonesundefinedundefined
