Dev Call Nov 26 2018 2300 UTC
Issues & Pull Requests
  • Extending the battery monitor library to be a more general power monitoring interface
Plane
  • Update
Copter
  • Update
Rover
  • Update
Attendee count (max): 25
Pre-agenda:
  • DJI API concepts
  • Tridge is keen
  • Spend a day to scope out what would need to be added
    • Basic ping style function to learn enough about API to see how big a project it is
  • DJI API has some mavlink hooks in it already?!
    • Can do some mavlink ops through their SDK?
  • Another serial protocol on a serial port?
UTC2304 - removing plane update event scheduler
  • Merged!
UTC2307 - removing NuttX
  • PR has been created
  • Passes CI!
  • FF has reservations about losing VRBrain support
    • Queries have been answered on the issue
    • FF wants the Makefile build system gone
    • FF: We haven’t given fair warning
    • Tridge: who to?
      • FF: VRBrain
      • Tridge: I gave them a year!
        • Private discussions
      • Tridge is comfortable removing VRBrain
        • It won’t be a surprise to the VRBrain guys
      • They were supposed to send tridge a schematic and a board so he could do the port
        • They haven’t
  • Publically we haven’t set a firm date
    • We have announced that 3.7 will be ChibiOS only
      • This PR is preparing for that
      • 3.10 for Plane as well
    • Tridge: Shall we set the date as the next dev call?
      • FF was thinking 6 months…
  • Hal F4 Light also requires Make
    • Too many people using Make
      • On gitter
  • “Make” actually works well now in tridge’s PR; it guides people through the use of waf
  • MdB isn’t comfortable with the timeframe
    • Too many things popping up
    • MdB flies master
      • Missing too many things in Plane stable for QuadPlane
    • E.g. i2c lockup
      • Behaviour under NuttX was worse!
    • Flying px4-v3 master
  • “As long as the old one is available people will keep using it”
  • Tridge doesn’t fly NuttX for releases
    • He only tests ChibiOS
  • Not doing this is holding up doing HAL cleanups
  • Nate points out the old NuttX IO firmware was in use until recently
  • [10:18 AM] To Weekly devcall: @MdB what would you consider a good timeframe?
  • [10:19 AM] (Channel) MdB: Peter: I still want the dual release with parity, but apparently that can’t happen
  • [10:19 AM] (Channel) MdB: I’d be a lot happier with the end of year
  • Master is supposed to be our next generation
  • Tridge’s talk in February said it was going away
    • MdB said it stated there would be parity and that’s now not happening
    • Tridge thinks it was actually “dual release”, not “parity release”
  • Tridge believes we’re now at parity
    • MdB thinks that we should have releases in this state
  • Randy is happy for the next release of Copter and Rover to go out without NuttX and would prefer this argument to stay about Plane
  • MdB wants a Plane release off master with both platforms in it
    • Tridge doesn’t want to do that
  • [10:27 AM] To Weekly devcall: @MdB I’m really not sure what a dual-release off master would gain. People will just keep flying NuttX on it.
  • Craig to MdB: can you fork from master and support customers from that for a while?
  • MdB doesn’t have time to fly ChibiOS at the moment
    • Tridge points out the opportunity to fly it has been there for a very long time
    • MdB points out it didn’t have feature parity until recently
  • Tridge wants time to restructure the HAL
  • 10:31 AM] (Channel) MdB: I think you’d see a wider commerical side but I’m just the one here
  • [10:25 AM] To Weekly devcall: 14,000 line delta between master and ArduPlane-3.9.2
  • 10s of thousands of APM downloads/month
  • Would make an archived directory to hold APM and NuttX builds
  • Nate would like a ChibiOS-only beta soon
  • Delayed another week because we haven’t managed to resolve on the call
UTC2341 - semaphore passing when it shouldn’t
  • Tridge will fix
    • Actually, tridge’s testing shows that it does fail
UTC2341 - https://github.com/ArduPilot/ardupilot/pull/9844
  • Add separate radius for landing vs normal approach
  • Ensures you’re far enough from WP to start approach
  • Separate land airspeed
  • Automatic would be nice
    • MdB thinks he has the maths floating around
  • Nasty p1 hackery
    • Fix determined
UTC2351 - power monitoring
  • Battery seems to be where this stuff is done
  • But as we grow and want to add things like overpower is this the right way to do it?
    • If we grow a function indicating what the power source is used for it might be a nice cleanup
    • Nate thinks so
    • [10:53 AM] (Channel) eosbandi: Dont forget other power sources such as generators or tethers
  • How about a “watt_max”?
  • Watt limit should scale with voltage
  • Discussions of rejigging things to be energy-based
  • Fuel-gauging
    • Temperature
    • Air density
  • Need to separate current-limiting from energy management
  • Amp limit per battery will be put in – MdB
  • Need to make sure tethers fail means copter lands
  • Some tethers appear as smart batteries, some don’t
UTC0004 - UAVCAN dynamic node allocator
  • FF has a few issues
    • Stated on issue
  • Storing IDs in filesystem isn’t great
    • Having an open file descriptor all the time isn’t cool
    • This will be replaced in the future
    • opening/closing in-flight is BAD
      • Put a limit (say 100) on open/close and then start to reject allocations
UTC0017 - Plane update
  • Nothing happened in stable
  • PixHawk4 crashes at particular flying field
    • PX4 project also has crashes with PixHawk4
    • Possibly a HW bug
  • Tridge has improved robsutness of s.bus parsing and dsm parsing
    • Much better now in ChibiOS vs NuttX
  • Solo doesn’t follow the DSM standard
    • Fixing involved extra robustness checks
  • 12 actuators in RealFlight FlightAxis simulation
UTC0019 - Copter update
UTC0021 - dataflash
  • Hw tridge bought isn’t suitable
  • Still looking for fixes
UTC0019 - Rover update
UTC0025 - lots of links for microsd to SD
[11:29 AM] (Channel) MdB: https://www.newegg.com/Product/Product.aspx?Item=9SIA7257AS5778&ignorebbr=1&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC--pla-Best+Price--Card+Reader%2FAdapter-_-9SIA7257AS5778&gclid=EAIaIQobChMIx6Csxajz3gIVCzlpCh2YEgx6EAQYBSABEgLwlvD_BwE&gclsrc=aw.ds
[11:29 AM] (Channel) CE: https://c1.neweggimages.com/NeweggImage/ProductImage/ABV7_131687527074608308PnAgLTekrK.jpg
[11:30 AM] (Channel) CE: https://www.amazon.com/LANMU-Extension-Flexible-Monoprice-Raspberry/dp/B01D9JIUU0
UTC0031 - does anybody have a setup to test a fix for a race condition in the statustext frsky stuff?
  • Nate
