Dev Call May 31, 2021
Issues & Pull Requests
Plane
Copter
Rover
GSOC
Attendee count (max): 13
UTC23?? - Copter Extended Tuning: change "Stabilize Roll (Error to Rate)" label to "Angle Roll (Error to Rate)" · Issue #2628 · ArduPilot/MissionPlanner · GitHub
Randy going to make this change
UTC23?? - Added Holybro CAN GPS by tridge · Pull Request #16931 · ArduPilot/ardupilot · GitHub
  • Support for HolyBro CAN GPS
  • Merged
UTC23?? - AP_Mission: Fixes crash in copter when uploading MAV_CMD_NAV_LAND with NaN as p4 by joshanne · Pull Request #17430 · ArduPilot/ardupilot · GitHub
  • Fixes fcrash in copter when uploading mission items
UTC23?? - AP_BLHeli: Remove duplicated code, use existing AP_Math CRC function by amilcarlucas · Pull Request #17509 · ArduPilot/ardupilot · GitHub
  • Duplicate code removal
UTC23?? - AP_BattMonitor: Record and report UAVCAN Battery Info temperature correctly by joshanne · Pull Request #17547 · ArduPilot/ardupilot · GitHub
  • Report and record uavcan battery info temperature
  • Kelvin float16 not great
UTC2337 - fix ground effect compensation
UTC2343 - Plane: Add options to USE_REVERSE_THRUST to cover all flight modes by Hwurzburg · Pull Request #17556 · ArduPilot/ardupilot · GitHub
  • Reverse thrust for all flight modes
  • We’re going to run out of bits in USE_REVERSE_THRUST
    • Need to widen it to 32 bits
UTC2347 - metadata corrections in parameter metadata
  • Removes the values examples
  • UI issue in MissionPlanner
    • Can’t set an arbitrary value
  • We’ll close this issue and open one against MissionPlanner
UTC2354 - AP_NavEKF3: make time-horizon OF data a local variable by peterbarker · Pull Request #17585 · ArduPilot/ardupilot · GitHub
  • Moves global state to be a stack variable
  • Saves 60 bytes of RAM per EK3 core
  • merged
UTC2356 - Tools: update default params for copter-optflow.parm by rmackay9 · Pull Request #17590 · ArduPilot/ardupilot · GitHub
  • Updates a little convenience file that Randy leaves around for easily setting up vehicles
  • Merged
UTC2357 - Copter: Remove WP Delay in ZIGZAG Mode by S-Curve by muramura · Pull Request #17596 · ArduPilot/ardupilot · GitHub
  • Delay was needed to avoid corner-cutting
  • Added about a year ago
  • We’ll lose the ability to pause for several seconds
UTC0002 - AP_Stats: Notify GCS of the current flight time by muramura · Pull Request #17600 · ArduPilot/ardupilot · GitHub
  • Spam GCS with messages about flight statistics
  • Maybe use a LUA script instead?
  • closed
UTC0008 - Copter: these two errors are too common to be called "emergency" by tridge · Pull Request #17574 · ArduPilot/ardupilot · GitHub
  • Changing the shoutiness of the messages
  • Emergency was way too much
  • We’ll go with notice for now
  • For 4.1
  • False-positives are killing the utility of this patch set
  • PH does the yaw imbalance
  • LTH is responsible for thrust-loss
  • 50% emergency?
  • Otherwise notice
  • Maybe a must-be-flying-for-10-seconds before warning threshold
  • Moving to be a warning based on imax not i
  • Rate graph should be used for actually looking for problems on a vehicle in the logs
  • Tagged as MergeOnCIPass
UTC0024 - Plane update
  • Plane: stable 4.5.x issues list · Issue #15941 · ArduPilot/ardupilot · GitHub
  • Tridge is getting some more local aircraft to test
  • Tridge wants testing of new landing approach code on real vehicle
  • Slewing the target altitude rather than the final alt straight away is going to happen for (mixed-QRTL)
  • Sprung-throttle and landing
    • Copter doesn’t have control of descent rate
    • Want control for ship landing to let waves go by before landing
  • Horizontal repositioning requires a pause in descent
    • Can’t do so while descending or aircraft gets disturbed
UTC0028 - Copter: 4.1.0 issues list · Issue #16478 · ArduPilot/ardupilot · GitHub
  • Copter update
  • Increasing number of reports coming in
  • Good progress in last week
  • Outstanding issues
    • Guided mode update PR needs more looking at
    • Terarange evo 60m has large spikes in it
    • Watchdog reset on omnibusf4pro
    • MissionPlanner crashing bug
    • DMA.txt from sys?
      • First-attempt-to-fetch will always fail
      • Maybe return zeroes instead?
        • And the same for other files
    • Gps-from-yaw with-cross-linked-GPS documentation needed
    • Uarts.txt is what’s required not DMA.txt
    • 10 IMU resets in last 10 seconds
      • Freertos scheduling issue
    • Serial pass-through is not working for GPSs
      • Protocol to zero or minus 1
      • Or GPS type to zero
UTC0055 - Rover: 4.1.0 issues list · Issue #17116 · ArduPilot/ardupilot · GitHub
  • Rover update
  • D-shot broken on Rover
    • Moving UGVMotors out to libraries directory
UTC0056 - GSoC update
  • Still in bonding period
  • Rishabh’s doing precision landing with 3D cameras
    • And not waiting for bonding period to stop
UTC0058 - close
