Issues & Pull Requests
GSOC
Plane
Copter
Rover
Tracker
Attendee count (max): 17
UTC2301 - https://github.com/ArduPilot/ardupilot/issues/11379
- Force-arming Rover doesn’t work in MissionPlanner
- Should we have an item in the GCS if it doesn’t work?
- Why is forced arming important?
- Means users can arm without disabling all their arming checks
- Reduce number of people flying with arming checks disabled
- Has made a difference to tridge
- All his vehicles have arming check 1
- MAVProxy gives audible warning if any checks are disabled
- Peter has a PR which adds it to Rover
- Should be able to arm Copter in auto mode from a GCS
- Plane allows arming in auto mode
- So why not Plane from sticks
- Randy is worried about vehicle taking off by itself
- Randy is OK with arming from GCS in auto mode
- Rover needs GPS to arm
- Should have a test to ensure it doesn’t happen again
UTC2318 - https://github.com/ArduPilot/ardupilot/pull/11377
- Collect crc functions into same file
- merged!
UTC2319 - https://github.com/ArduPilot/ardupilot/pull/11360
- Add simulated RGBLed
- Maybe Stephen could be convinced to port for Windows?
UTC2322 - battery from mAh to percentage
- No movement since last week
- Fair bit to read on this issue
- [9:24 AM] (Channel) MdB: I don’t think it fixes anything, won’t be chasing it personally
- MdB: Still has the fundamental setup problem he already had
UTC2324 - https://github.com/ArduPilot/ardupilot/pull/11347
- One big long file is no worse than two (Randy)
- LogFile was logging individual messages
- New messages would go where messages were logged
- Maybe Messages.cpp might be better than merging the two
- Kill this PR, clean it up putting messages in Messages.cpp (and nothing else)
UTC2332 - https://github.com/ArduPilot/ardupilot/pull/11344
- Pete said we shouldn’t cover this this week
UTC2333 - https://github.com/ArduPilot/ardupilot/pull/11317
- Copter stable IOMCU
- Going into Plane release as well
- Gives DSM bind
- Well-tested in master
UTC2336 - https://github.com/ArduPilot/ardupilot/pull/11266
- Simple patch
- Commit message isn’t quite right
- Define for number of i2c buses?
- Master has a macro which loops through the buses
- For_all_i2c
UTC2339 - https://github.com/ArduPilot/ardupilot/pull/10859
- HAL_MINIMIZE_FEATURES was done
- Code was changed to address issues from last time we looked at this
- Merged!
- Very expensive cameras need this sort of log
UTC2340 - https://github.com/ArduPilot/ardupilot/pull/10409
- MdB thinks there’s a problem with one particular check
UTC2340 - https://github.com/ArduPilot/ardupilot/pull/10402
- Rotor speed heli patches
- Review was done
UTC2346 - GSoC
- Meetings required!
- Having docs on how to run new features is a good idea
- Not necessarily as a Wiki page
- Just in the PR description would be fine
- Some progress on the MAVProxy stuff
- Things moving along with Patrick’s student
- Funding committee have been moving fast on approvals which is good
UTC2357 - Plane update
- New beta soon with spektrum update to switch to ChibiOS parsers
- No work on larger update based on master
- Probably a few weeks off on this
UTC2358 - https://github.com/ArduPilot/ardupilot/issues/9498
- Randy and Copter
- Copter 3.6.9 later today
- Rover 3.5.1 went out
- No plans to do more in the immediate future here
UTC2359 - object avoidance
- Randy is actively working on this
- https://www.youtube.com/watch?v=KuJLxMEcPnU
- Real vehicle has issues
- Outdoors in middle of day is useless
- False obstacles
- Sf40c should do better
- Randomly rolling around isn’t great
- Wanders its way around
- Control error?
- Indecision?
- Randy is considering changing the algorithm to project from a different point
- Direction from a projected point rather than the vehicle itself
- Create intermediate origin
- Add hysteresis into decision making
- Remember last decision for a while
- Only update if better than some margin
- Destination moves around no matter what
- Moves based on vehicle’s current position
- Currently moves @10Hz
- Morse is great to have for this
- Bit difficult to know what’s going on
- Don’t know what the proximity sensor is seeing
- LIDaR is useful
- Having real scene data would be awesome
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/11334
UTC0017 - unexpected emergency stops
- No RC glitch in logs
- Oscillating RC input is theory
- Debouncing present in one of the firmwares
- We will improve logging on RC in both stable and master
- Both users had custom code
- IO firmware parsing SBUS
- Two in one week makes us suspicious
