Issues & Pull Requests
GSOC
- Student are announced
General
- New Bootloader
Plane
- Release Update - Should be a new release in a few days
Copter
Rover
GSOC
General
Plane
Copter
Rover
Attendee count (max): 22
Pre-agenda:
Servo autotrim
This is what prearms are forâŚ
Compass cal on Copter breaks with the watchdog reset
No Craig,randy running call
UTC2305 - freezing integrators
Rover has stick-mixing now which mixes in at alow level like Plane
https://github.com/ArduPilot/ardupilot/pull/11261
Freezes the integrators
Randy doesnât really like this approach
Should move the stick mixing up a level
Rover already has stick mixing of a sort with the throttle nudging
Goes in as an extra desired speed
So no integrator build-up
Put it in at the turn rate controller level
Plane mixes in at the desired attitude level OR the servo output level (sitckmixing-direct)
Tridge would like to take out the servo output level one
[9:09 AM] (Channel) MdB: itâs awful
[9:09 AM] (Channel) MdB: I turn it off aggressively
[9:10 AM] (Channel) MdB: itâs caused me more headaches (personally) itâs non intuitiveâŚ
[9:10 AM] To Weekly devcall: Interesting. I love it.
[9:11 AM] (Channel) MdB: If you ever hand the plane to someone who doesnât know how to fly RC competently itâs a great way to watch your aircraft do everything slightly (to very) off
[9:11 AM] (Channel) Naterater.mobile: 10000% useful during landing flare
Trims must be taken into account! Critical!
UTC2312 - https://github.com/ArduPilot/ardupilot/pull/11217
Tridge has read through it and is happy with the change
Will break jsbsim unless jsbsim is updated
Timestamp in protocol but timestamp is only right once per universeâŚ
Patch makes timestamp be correct time
Detect special timestamp and use old method?
But this is currently pending on upstream merging a patch
Tridge will put a note on the ticket to ensure theyâre not waiting on us
[9:15 AM] (Channel) JP_mob:
Simfinite is reworking the jsbsim side of it still
UTC2314 - https://github.com/ArduPilot/ardupilot/pull/11132
SITL fix wait clock to correct delay
In CMAC avoidance code
What does this actually do?
MdB: Effectively marches time backwards as well as forwards
Tridge doesnât understand the patch but recalls the timestamp issues
Found commit comment: Prevent deadlock in SITL
This was probably a hack workaround for that deadlock
UTC2317 - https://github.com/ArduPilot/ardupilot/pull/11112
Update dspoiler autotrim
Forgot about autotrim for dspoiler on stuff which went in a little while ago
Should not treat bits as booleans
Needs testing
Tridge remembers getting this incorrect in the first place
Fly along, set trim to incorrect value, make sure plane fixes itself
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/10952
Pete has done updates and added a reset method
Switch or via mode issues again
If you disarm in autotune and rearm you should be able to carry on
Merged!
UTC2323 - https://github.com/ArduPilot/ardupilot/pull/10859
Add NMEA output
Has requested changes on it
Tridge wants minimise features
UTC2329 - https://github.com/ArduPilot/ardupilot/pull/10402
Tradheli guys
Still pending Randyâs help on this one
UTC2330 - 5 GSoC students!
Community bonding period
Peteâs feeling very bonded
Add support for commercially available wind speed and direction sensors
Add support for motor sailing
Improve handling of failed tacks
Support for wing sails controlled using âelevatorâ control surface
Sea state classification
Add functionality to learn, store and use a boat speed polar
Track wind shifts and implement probabilistic decision making
Mapping functionality to allow a defined area to be mapped as quickly as possible considering the limitations of a sailboat
MattKearâs turned up to the devcall - welcome!
Tradheli autonomous rotation
Want no-complicated-setup
No RPM sensors with luck
Robust generic approach that will be very useful to other people that they can rely on
https://summerofcode.withgoogle.com/organizations/5883027960365056/
Will be working with Chris and Bill
Has RealFlight set up
Three other students not on devcall
Akshash has already made a nice PR against MAVProxy
Rajat-Singhal is working on AirSim simulator support for ArduPilot SITL
Nguyen Hoang Thien
Patrick P is looking after
Discuss has some blog pages for projects
This is a 3 month project
Should have at least three blog posts
Working on public forums
very, very good proposals didnât get up
Not enough mentors
We like students coming back and mentoring future generations
UTC2337 - new bootloader
Fixed boot when GPS or whatever on same UART the bootloader is listening on
Ublox protocol can generate a pattern of bytes that makes the bootloader think itâs being talked to
Board just doesnât boot
Also now supports downloading firmware from the board again!
Hex or flash
You end up with a 2MB .BIN on a 2MB board
Do we need to announce the bootloader+watchdog interactions as part of the release?
UTC2345 - two PRs related to IMU issue still valid or not?
One from tridge, one from Jon
Tridge thinks he can close his own
Jonâs one needs a bit of work
Killing IMUs in SITL could come in
RC switch to kill IMUsâŚ
#ifdef SITL around it?
Went several years where we had a serious bug which would have been caught by having it in
Could have an autotest
Protect rc channel option with a devop or board bit
Jon resets gyro biases and other learned state when switching lanes
Various advantages in that
Should mark this as WIP
Paulâs got concerns about validation, especially for an emergency release
But itâs good code and will help the EKF remain stable, so weâd like to get it in
UTC2351 - Plane release updates
New stable in next few days
Primarily for the new bootloader
Very minor Plane stable
UTC2352 - Copter and Rover issues
Betas for 3.6.9rc3 for Copter and 3.5.1 for Rover are out
Critical IMU fixes already went out
Any beta testers out there? Would like some feedback
Cx-of sensor on any board is confirmed to work
Copter will have an rc3 with a cuavv5 fix
Twin power fix logging fix
Affects 5 or 6 different boards
https://github.com/ArduPilot/ardupilot/pull/11281
Merged!
Pthread issue
3.5.1 Rover will be out soon
UTC2356 - Rotor speed governor stuff
UTC2357 - other
UTC2358 - new team member vote did not pass
UTC2358 - AUVSI
Lots of vehicles running Here and Cube
Lots of people proudly declaring their running ArduPilot firmware
Not much in the way of DJI gear
UTC2401 - close
Should we expect an official announcement for the GSoC with an invitation to the students to present their respective project on GCSoC 2019 Forum ?
I already announced Thien Nguyen @hoangthien94 on the vision channel ; https://gitter.im/ArduPilot/VisionProjects but going on the forum gives them more exposure.
Btw announcing on FaceBook would be nice too.
