Attendee count (max): 22
UTC2300 - https://github.com/ArduPilot/ardupilot/pull/16719
- Offboard guided broken things
- Do-change-speed should only affect guided and auto?
- Lots of manual testing done in SITL
- 0 isnât a good value for airspeed?
- Use >0 for a comparisonâŚ
- Airspeed override to be reset on entering any mode
- Can be merged once these things are addressed
UTC2312 - https://github.com/ArduPilot/MAVProxy/issues/874
- Fixes for MAVProxy crashing on mavflightview.py
- No PR to review for this yet?
- A delay might be OK to fix this one
UTC2314 - https://github.com/ArduPilot/MAVProxy/pull/502
- Will come back to MAVProxy PRs later
- Running short on time today
UTC2316 - https://github.com/ArduPilot/ardupilot/pull/16841
- Need to use same function for roll/pitch on the RC library
- Odd stick swapping for axes
- Comments also need fixing
UTC2317 - https://github.com/ArduPilot/ardupilot/pull/16833
- 16 bit mask for terrain following
- 32-bits might be better
- Parameter-protocol 24 bits isnât enough
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/16823
- Climb-before-return
- Maybe use a flight-option-bit rather than a full parameter
- RTL_OPTIONS rather than FLIGHT_OPTIONS
- Why do we do level-roll-limit rather than going straight?
- Roll might be require for fighting wind?
- Straight-line-across-ground rather than rollâŚ.
- Stop wingtip hitting ground
UTC2325 - https://github.com/ArduPilot/ardupilot/pull/16818
- Add height above terrain panel and warning
- Random pluscode changes
- Should check the Files tab
- Git add -p to avoid random changes
UTC2329 - https://github.com/ArduPilot/ardupilot/pull/16808
- Only run mission when armed
- Canât now arm the vehicle using mission
- As soon as youâre armed you know which waypoint youâre going to go towardsâŚ. After this PR that wonât be the case
- MdB cares that we can continue to run missions
UTC2335 - https://github.com/ArduPilot/ardupilot/pull/16787
UTC2337 - https://github.com/ArduPilot/ardupilot/pull/16751
- Can we afford the flash for this?
- Not really - closed
- Its a canât happen in a private function
UTC2339 - https://github.com/ArduPilot/ardupilot/pull/16725
- Amilcar will fly this in next couple of days
- Saves memory
- Adds features
- Use ESC telemetry library for data
- Cuts code
- Looking really nice
- Randy might be able to review before DevCallEU
UTC2341 - https://github.com/ArduPilot/ardupilot/pull/16721
- Single CAN frame to handle GPS status
- Separate message as nodestatus canât handle both gps and baro statuses
- AP_Periph act as multiple nodes was considered but hard to do
UTC2344 - https://github.com/ArduPilot/ardupilot/pull/16667
- Needs someone else to run it to make sure it works
UTC2348 - https://github.com/ArduPilot/pymavlink/pull/512
UTC2347 - https://github.com/ArduPilot/ardupilot/pull/14276
- Want MdB and tridge t odiscuss this i2c scripting thing
UTC2351 - Plane runway takeoffs
- Gergely has a few ideas
- Jets on narrow runways
- Suicide missionsâŚ.
- Hurricanes, Lightning, hail ice and so onâŚ.
- PR and issue will be raised for the runway issue only
UTC0001 - Copter update
- Copter-4.0.7 stable released!
- A few new issues on 4.0.x
- SD-card logging not working if the logs directory wasnât pre-existing
- Some sort of bug in AP_InertialSensor for a Matek board
- 4.1
- Lots of more on SCurves
- Leonardâs looking forward to this being done
- This is imminent
- https://github.com/ArduPilot/ardupilot/pull/15896
- This is very flyable
- Donât put this on your $25,000 drone unless you really, really want to
- Please be mean to it
- Last item for 4.1 beta release, really
- 11:05 AM] Peter Hall: Iâm keen to get some of the pending scripting stuff in
- Partially broken bendy-ruler obstacle-avoidance
- Will move very, very slowly when avoiding stuff
- New navigation is kinematic path planner
- To generate somewhat obstacle kinematic path you need to generate and follow a path
- Bendy-ruler and stuff uses older approach, multiple-updates of current location
- Not compatible with a path planner
- Input to scurve input shaper will need to allow ad-hoc path planning
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/14276
UTC0011 - https://github.com/ArduPilot/ardupilot/issues/12509
- Rover update
- Rover will not be getting SCurves as part of 4.1
UTC0011 - Heli autotune update
- Matek H743 board watchdogging
- Rotor-removed testing
- No additional watchdog resets
- Flew it again and no inflight shutdowns
- Tried autotune againâŚ.
- Logging bitmask was very oddâŚ
- PID and fast-attitude was requested but everything else was uncheckedâŚ.
UTC0017 - guided takeoff not looked at yet
UTC0017 - Off the floor
Partnerâs call tomorrow
Vote outstanding from last week, please look at it
GSoC?
- Announcement as to our acceptance is quite soon
ArduPilot Developer Conference
- https://ardupilot.org/dev/docs/events.html
- Object avoidance
- Navigation
- Control
- A few partners will also be giving talks
- If you want to talk poke Randy/tridge/James
- Limited number of slots for non-core developers
- Virtual get-together
- Maybe streamed live
- 75 people attended some of the calls
Mixing ESCs on the one vehicle?
UTC0023 - close
