CraigElder
(Craig Elder)
March 29, 2022, 7:07am
#2
Attendee count (max): 18
UTC1100 - Clean up Heli Autotune to reduce flash size by bnsgeyer · Pull Request #20238 · ArduPilot/ardupilot · GitHub
Clean up heli autotune to reduce flash size
Merged!
UTC1105 - Copter: improve shaping of rate controlled axes by bnsgeyer · Pull Request #20307 · ArduPilot/ardupilot · GitHub
Improve shaping of rate-control axis
Reworked to only affect Heli
Wraps old function so should only affect Heli
That does push flash usage up
Passing in lots of parameters which won’t really change?
Position control modes, when you enter loiter mode it sets the loiter acceleration limits etc etc
Leonard Randy and Bill agreed they liked this way of doing things this way
Doing it on mode enter might be nicer?
Costs on flash and runtime for passing the parameters
All other parameters change constantly, but these new parameter don’t
New parameters should live in ATC rather than in Copter instead?
Wouldn’t need to pass them….
Plane is kind of missing out on these new features in ATC a bit
Poking values into the controller rather than passing them in is probably a better way of doing things
More sharing we do across vehicles the better
Parameters inside the ATC?
UTC1118 - Disable Solo Gimbal except on CubeSolo and CubeGreen-solo by peterbarker · Pull Request #20328 · ArduPilot/ardupilot · GitHub
Only enable Solo gimbal on relevant Cubes
Also gets OreoLED
Merged!
UTC1125 - vector3: return w1 not zero vector by xianglunkai · Pull Request #20369 · ArduPilot/ardupilot · GitHub
Return w1 not zero vector
Merged!
UTC1126 - Fix ESCs constantly arming on rover with dshot commands by andyp1per · Pull Request #20374 · ArduPilot/ardupilot · GitHub
Fixes ESCs constantly arming on Rover with shot commands
Put throttle on 2nd 3rd of 4th in pwm group then things wouldn’t work
Merged!
UTC1129 - Shorten dshot pulse width by andyp1per · Pull Request #20379 · ArduPilot/ardupilot · GitHub
Change dshot pulsewidth
Need tridge
Bumped to DevcallEU
UTC1130 - AP_NavEKF3: rewrite getLLH to avoid excessive indenting by peterbarker · Pull Request #20380 · ArduPilot/ardupilot · GitHub
Constant position mode doesn’t set altitude?
PH thinks the bug does exist
People liked the reformatting
UTC1135 - Blimp: remove duplicated and unused params by Hwurzburg · Pull Request #20381 · ArduPilot/ardupilot · GitHub
Blimp Wiki is up!
This removes duplicated and unused parameters in Blimp
This isn’t all of them
But most of them
Failsafes aren’t working in Blimp right now
Blimp Home — Blimp documentation !!
merged!
UTC1136 - SP Racing H7 extreme updates by andyp1per · Pull Request #20385 · ArduPilot/ardupilot · GitHub
H7 Xtreme updates
Merged!
UTC1139 - AP_Param: fixed param class conversion code by tridge · Pull Request #20388 · ArduPilot/ardupilot · GitHub
fixes parameter keeps getting reset issue
Merged!
UTC1141 - HWDEF: add SLCAN OTG port, correct defaults.param errors by Hwurzburg · Pull Request #20391 · ArduPilot/ardupilot · GitHub
Qiotek H743 in Orca
SLCAN OTG port nor right, defaults.param incorrect
Merged!
UTC1144 - Plane: stable 4.2.0 issues list · Issue #15941 · ArduPilot/ardupilot · GitHub
No Plane update today
New beta released
Played with RC failover
Throttle-threshold-failsafe does not work in this case as that’s done by the controller
Good text output now for RC failover
UTC1152 - Copter/Rover: 4.2.0 issues list · Issue #20192 · ArduPilot/ardupilot · GitHub
Terrain alt issue
Vehicle hitting ground too faster
Not slowing down at land alt correctly
Caused by subtle change in terrain library
Doesn’t slow 10m above home, slows down 10m above terrain
Terrain adjustment which got removed
Another PR went in to restore the functionality
When you arm and takeoff it assumes that the vehicle is on the ground
So it zeroes the terrain altitude
Another beta coming out this week
Redux ~middday
All-zeroes watchdog
Scary
Peter couldn’t find anything in the log
Need to get something in place, even if it just some more logging
Bdshot had stack overflows?!
Maybe the crash catcher might show something
Bumped to DevCallEU
UTC1156 - heli
Autotune testing highlighted an issue
determines max allowable p and d gains
If it can’t it should stop
Direct-drive fixed-pitch rotor didn’t like autotune
Spinning at high rate in yaw
ESC gave up
No ESC logging
Being commanded appropriately
Overcurrent shutdown?
Overtemp shutdown?
Dramatic shortage of ESC manufacturers who understand multirotor requirements
10:57 AM] Peter Hall: autotune does tend to catch out such issues.
[10:59 AM] Peter Hall: its about as agressive as the vehicle will ever see, especially since vehicle are not really they run in when people are autotuning.
Flash-reduction PR to go back into 4.2
UTC0005 - Rover update
Testing is going well
More testers than usual
SCurve navigation
Will merge soon
Won’t make 4.2
Beta3 coming soon
UTC0009 - GSoC
Looking forward to submissions
Just a few more days of the current period
Applications start next Monday
UTC0012 - Conference
Next Friday
8th/9th/10th
Thursday evening US
Tentative schedule
UTC0011 - close
