Dev Call Mar 18 2019 2300 UTC
Attendee count (max): 17
UTC2304 - https://github.com/ArduPilot/ardupilot/pull/10837
  • Mark ready this is ready for further testing
  • 3-vs-2 tailsitter
  • One has integrator the other doesn’t
  • Target attitude vs target rate
  • Not really an integrator
  • Early return in qacro?
    • MarkW has been considering this in terms of tailsitters
    • So early-returned from qacro
    • Check is_tailitter
    • Pete’s been thinking in terms of ordinary quadplane
      • What about the AddictionX?
        • What happens to its control surfaces?
          • Tested and it worked
      • Feature-creep to consider QuadPlanes?
        • Have to refuse QACRO for a normal quadplane
          • Or stop control surfaces (moving and motor)
            • Separate work to get those working in qacro for a normal quadplane?
  • Tested on both old and new airframes
  • Merged!
UTC2313 - https://github.com/ArduPilot/ardupilot/pull/10836
  • Fixing a bug in attitudes
  • Couldn’t arm
  • Attitudes_consistent
  • Still something going on with ahrs trim
  • Some tailsitters require 0.2 radians (1 degrees) trim
    • In fixed-wing mode
    • Won’t arm because of threshold in test
    • Convert all to common frame then compare
    • Or add trim values to margin
  • Accounting for dog-chewed propellors
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/10828
  • AC_AttitudeControl - fun mathematics matrix algebra
  • _M and _P
    • Multicopter and Plane
  • Docstrings
  • Quaternion inverse expensive?
    • Inversion multiply functions can be much more efficient
    • No, not expensive - sign change
  • Need to look hard for things like division-by-zeroes
    • Particularly any state change which will be persistent
  • Constrain floats?
    • Wrap pi
  • Tridge relies on Mark and Pete to maintain tailsitter
    • Means they have to be very careful as tridge won’t be checking extremely hard
  • Would be nice to get some video
UTC2329 - https://github.com/ArduPilot/ardupilot/pull/10819
  • Tridge thinks its good
  • merged
UTC2331 - https://github.com/ArduPilot/ardupilot/pull/10818
  • We should have a clang++ thing in CI
  • Need a MacOSX CI option
  • We’ll be killing AppVeyor
UTC2334 - https://github.com/ArduPilot/ardupilot/pull/10806
  • Three bugfixes in one
UTC2337 - https://github.com/ArduPilot/ardupilot/pull/10748
  • Add 0,0 functionality
  • Can be merged after that
UTC2344 - AP_AHRS: add new method get_quat_body_to_ned()
  • There was a TODO to add this
  • So Mark added it
  • merged!
UTC2345 - https://github.com/ArduPilot/ardupilot/pull/10720
  • Needs Randy to look at it
  • It is a safety thing
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/10634
  • Should we move rebooting up in the HAL
  • Too many concepts of armed in the code
  • merged
UTC2353 - https://github.com/ArduPilot/ardupilot/pull/10614
  • Crow flaps
  • Tridge still needs to look at it
  • Video!
  • Added dlg glider model
UTC2355 - https://github.com/ArduPilot/ardupilot/pull/10570
  • Hard to review this one
  • If MdB is OK with it then we can merge it
UTC0002 - https://github.com/ArduPilot/ardupilot/pull/10499
  • Needs testing
  • Will test this week
  • Memory reclamation discussions to be had!
    • Over-allocation of buffer sizes
    • Scaling buffers
    • Stop allocating buffers on DMA buffers
    • [11:09 AM] To Weekly devcall: We could add some state logging into our memory allocation routines so we know where we’re allocating?
UTC0010 - https://github.com/ArduPilot/ardupilot/pull/10457
UTC0020 - https://github.com/ArduPilot/ardupilot/pull/9716/files
  • Requires Randy to look at it
UTC0021 - https://github.com/ArduPilot/ardupilot/pull/9143
  • Add license boilerplate
  • Add explanation of what it does
  • Do not add underscores to variables
  • A few more comments would be nice!
  • Enum shouldn’t be 32-bit
  • Enum should be declared with (1<<1) etc etc
  • Can be merged after these changes are made
UTC0027 - https://github.com/ArduPilot/ardupilot/pull/9017
  • RTL changes need Randy to look at them
UTC0029 - fuel flow battery issue
  • Fixed problems Michael saw
  • Worked with Buzz on this one
  • MdB has no complaints left
  • Someone else wants to do another backend
    • Some PWM values
    • Some give pulse-per-volume
    • Which channel is it coming in on?
      • Use RC_Channel option for it!
  • How does this work on a mixed-input thing?
    • E.g. with sbus
  • Using RC options for RPM etc etc would allow us to solve the reuse problem
    • Brd_pwm_count stuff
  • Merged!
UTC0034 - warn-if-unused on AHRS
UTC0042 - https://github.com/ArduPilot/mavesp8266/pull/2
  • Still doesn’t work for tridge
  • Peter will iterate
    • Dash! Gah!
UTC0046 - GSoC
  • GSoC section on Discourse
    • Need to answer students who post stuff there
  • Also on Gitter
  • Need a good project
  • [11:48 AM] (Channel) …: Maybe harsh, but it’s made it clear enough that if theycan’t figure out how to propose a project I’m not sure we need to be obsessing about that person…
  • Perhaps repost this:
UTC0049 - Plane update
  • Others are doing the hard work!
  • Tom is keen on getting Onion in
UTC0053 - going up as part of RTL - is it in stable?
  • MdB think it
  • May have already been fixed in stable
    • Nate to supply information
UTC0054 - backport of PWM rangefinder
  • this should get into stable
UTC0100 - developer conference
  • Many people on this call will be in CBR shortly!
  • Good start yesterday with Miro, Yibo, James and Jonathon
  • Lots of people starting to roll in
  • Tridge yet to come up with something to talk about
  • CAN peripherals
    • Compass and GPS libraries
  • Currently in pre-conference-week
    • Weekend conference coming up!
  • Possible live-stream of panel discussion
UTC0104 - some quick live-patches for master
  • Compilation fix
  • Warnings fix
UTC0111 - rebase of Amilcar’s stuff
  • On top of current corrected branches
