Conference
Issues & Pull Requests
GSOC
Copter
Plane
Rover
Attendee count (max): 24
UTC2300 - conference update
- Congrats to Randy and Tom for an award
- And Jani for an appointment
- Vice President of china uav group
- Huge well-funded UAV group
- Funders of conference
- Photos https://photos.app.goo.gl/w23i4szmwEws4jj36
- Conference went really well
- Mostly local Chinese manufacturers
- Thanks to Hex for the beautiful both!
- Million quadplanes there
- Lots of military stuff there
- “Uncomfortable amount”
- Over 30%
- Big UAVs
- Large quadplanes and mulitcopters
- Should get at least 3 or 4 new partners
- Treated very well
- One day of speeches
- Some similar to Canberra speeches
- Tom did a great git one one
- Some great individuals came around and chatted
- Robsense guys
- Showed videos of their swarming stuff
- Impressive
- 50 drones or so
- SkyViper swarming!
- 10 or 20
- On gitter?
- Randy Mackay
@rmackay9 09:40 I met three developers at the recent Shenzhen conference who had done a drone swarm with a bunch of skyrocket drones. I’ve misplaced your business card so please ping me!
- Videos need to be edited
- Tom’s phone has a 15-minute limit on videos…
- All talks in English except one speaker
- And translators for both directions English <-> Chinese
- Translators asked about a few vocabulary words
- Engaging more with the Chinese developer community would be a good thing to do
- Language barrier makes it a little difficult
- Need a couple of Chinese-speaking-developers who can act as some sort of gateway?
- Things like universities
- Next conference in October will have a lot more developers
- This was a bit more like Interdrone
- Next conference will be more developer-heavy
- Might be more of a developer-culture-connection there
- Should we have a Chinese-language section on our forums with moderators to bring things across?
- Great-firewall didn’t block everything
- WeChat integration is amazing!
- Everyone uses it!
- Pervasive
- Us hopping onto WeChat wouldn’t help because of language barrier?
- Machine translation is embedded!
- Philip: it does work!
- Randy: used it for a while after previous trip
- Someone else would translate it for him
- Privacy issues with WeChat?
- Probably works on every platform you could think of
- Tridge: China is a huge group of people
- More people coding AP in China than the rest of the world simply based on numbers?
- [9:15 AM] (Channel) JW: http://rovmaker.cn/
- Hex has people engaging with these developers full-time
- Creating an ArduPilot training school
- As in physically building a training school
- See this in October conference!
- Fluent English speakers from Hex in the booth every day!
- MQ - zig-zag mode
- Hex conference
- Food will be awesome!
- Booked out entire hotel
- TP: https://photos.app.goo.gl/w23i4szmwEws4jj36
- [9:53 AM] (Channel) TP: Huge dump of pictures from ShenZhen 2018
UTC2322 - https://github.com/ArduPilot/ardupilot/pull/8708
- Correct edge case on arming
- If primary compass is unhealthy we would assume you weren’t trying to use compasses at all
- Instance vs non-instance call
- Looks good to tridge
- FF has concerns about the learning behaviour
- Compass-learning means we don’t use the compass initially until we’ve flown for a while
- Need to fly around a little before you can switch to a position-requiring mode
- Merged!
UTC2322 - https://github.com/ArduPilot/ardupilot/pull/8706
- I2c bus mask
- Luis’ fault
- Lucas provided feedback on the API which needs considering
- Behaviour unchanged for existing i2c buses
- E.g. Cube has 2 i2c buses, one of them notionally internal
- Compasses they both look external
- Didn’t want to change ordering of compass
- Made a more complex change to preserve ordering
- Automatically reorder based on compass IDs?
- Shift offsets around based
- You could have lots of i2c buses, particularly on Linux boards
- Startup on Linux and bus-ordering guarantees?
UTC2331 - https://github.com/ArduPilot/ardupilot/pull/8699
- Detect GPS at wrong baud rate because uart not cleared
- This changes so that begin() implicity flushes buffer
- F4Light not done
- Should ping n-g to see if he wants to fix it
- Less obvious implementation
- Some testing done with Here GPS
- FF spots a dangling variable in real-time
UTC2334 - https://github.com/ArduPilot/ardupilot/pull/8698
- AP_RangeFinder
- Enable parameter?
- Lots of parameters even if you don’t have rangefinders
- This would hide 38 parameters from the GCS
- Tridge thinks it is reasonable
- Parameter CRCs instead of enable parameters?
- Enable parameters are hard to cope with on the GCS
- Don’t know which are enable parameters
- Hard to do UI based on it
- Take CRC of all non-volatile parameters, package with parameter download
- Allows GCS to cache
- CRC itself is a virtual parameter
- GCS do a param-request-list
- Vehicle sends fake hash-crc parameter which has the CRC in it
- Then it start streaming parameter in normal way
- Then GCS can see hash, check the hash for a hit
- If it doesn’t match, just continue
- If it does match, the GCS sends the parameter back with the same value and the vehicle should stop streaming
- How do you blacklist a parameter?
- Are gyro offsets sent?
- We calibrate gyros at boot
- So we could stop streaming but volunteer the volatile parameters
- Waypoint count?
- GND_TEMP?
- Used for correcting barometer in-flight
- [9:43 AM] To Weekly devcall: One interesting problem - when we volunteer a parameter we use 65535 as its parameter number
- [9:44 AM] To Weekly devcall: We only use a sequence number when doing the streaming. So we’d kind of need to “filter” the stream rather than halting it, I think.
- Parameter download over radio is brutal
- This can make it faster!
- Increasing parameter rate would help
- Enable parameters give QGC fits
- Fixed-wing to quadplane is OK
- But the battery stuff is tough
- Download-range method instead?
- “Give me the following 20 to 30 parameters”
- Still may have that initial 15 seconds, which Don doesn’t like
- JW: I’ve played with the crc32 on stm32 before
- [9:49 AM] (Channel) JacobWalser: hardware crc32
- Maybe we should volunteer parameters when an enable parameter is enabled
- Should we send all parameters and leave it to the GCS?
- Maybe we should tell the GCS about changes to the parameter structure
- E.g. there’s new parameters in this range
- MdB: it’s 17 per batt monitor, about to be 3 monitors soon ™
- 17 params per battery monitor
- If you enable a battery monitor in QGC then you have to wait for the parameters to arrive before Don can show the user interface
- Hash of a group of parameters
- Enable parameter advantages
- Vehicle setup parameters often have UI built around them
- [9:56 AM] To Weekly devcall: I wonder how much faster we could make parameter download if we were to compress things. parameter strings are all 7-bit-clean and are very repetitive!
- [9:57 AM] (Channel) MdB: Peter: more win to just stream faster first
- [9:57 AM] To Weekly devcall: @Michael 900MHz radios still suck
- TP: I’ve always HAAAAAAATED the _ENABLE hiding. Always.
- Split enable parameter into two
- Major-subsystem flag
- Minor-subsystem flag
- GCS can choose behaviour?
- Parameter has no-bits-set or other bit set
- Changes what gets sent
- Extra command to set level
- UI elements will refresh immediately on QGC
- Mavlink2 on USB?
- [10:00 AM] (Channel) TP: would LOOOOOOOOVE better Java support on MAVLink2
- [10:00 AM] (Channel) MdB: tom… lol
- [10:00 AM] (Channel) TP: MAVKink v2 is pretty much only supported in C
- Rangefinder PR will be held open pending the other one
UTC0005 - https://github.com/ArduPilot/ardupilot/pull/8695
- Randy was generally ok with it
- Changed some behaviors like usb led dimming
- Changed some of copter ekf handling
- People do connect companion computers via usb, so they are not getting all protections we should offer
- Randy absent for approval now, we believe peter, merged
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/8409
- Tridge has gotten a little obsessed with GPS time over the last week
- Hooked up PPS pin
- Patch which allows use of logic analyzer to look at timings
- Synthetic PPS
- Lags real one by about 60ms
- Needs flight-testing
- Timing jitter just plummets a lot
- Nate?
- [10:09 AM] (Channel) Naterater.mobile: YES
- Amilcar also had a great test setup for this
- May need to change EKF’s expected-lag
- To ~60ms
- Ask GPS what lag is
- Forward propagation of timing data into EKF can go in after this one
- Most GPS you can’t get the pps signal out
- Usually shielded
- Press-button-for-safety switch could have pulses on it?!
- [10:14 AM] (Channel) TomPittenger: hey @MdB, please take a look at this https://photos.app.goo.gl/9GRk4h4AdP34vkRMA
GPS L1/L2 module, about $350 today, hoping to be $250 next year
UTC0016 - sub remove forward/lateral
UTC0020 - https://github.com/ArduPilot/ardupilot/pull/6842
- Ppoirer would be a good person to test this PR
- And Grant
- Rover would still need to be done
- merged!
UTC0025 - moving reboot up
- Scope traces show it appears to be working as expected. Tested with Hal Nuttx.
- Jacob can test within the next day
- Can be merged after that
UTC0029 - https://github.com/ArduPilot/ardupilot/issues/8670
See also Discuss forum post where RTL caused bad behaviour
- No log but there is video
- RTL was probably triggered and turn happened to close to the ground
- Should we be climbing before any turn after an RTL is triggered
Knowing where the ground is can be problematic
Demanding a climb can also be a problem if you are dead-stick
- Timeout required in this case?
- Pulling up if you don’t have power is likely to induce a stall
- Battery failsafe says don’t pull up
- Gcs might mean pull up
Any parameter would be obvious in hindsight
- RTL_TURN_MIN_HEIGHT
- Certain number of metres above home before turning in RTL
- Differences between takeoff and landing altitudes…
Plane below takeoff height in this case
10:33 AM] (Channel) MdB: Also for a lot of use cases you must turn in RTL for a lot of situations
[10:33 AM] (Channel) MdB: Climbing first is untenable for field clearance reasons…
[10:33 AM] (Channel) MdB: It’s a fallback outside of the mode page (gets to be failsafes)
- Indefinitely climbing is a no-no in most circumstances
- So a timeout and/or distance timeout
- Consider geofences too
Terrain data would give a rough estimate of height
- We have code to limit roll close to ground
Command take-off mode before doing the RTL?
Higher than point you entered RTL?
- Limit bank angle based on height you entered RTL?
- Wingtip-dragging-prevention
- All autonomous modes where you are trying to climb?
- Or maybe just RTL as MdB has use cases which would be problematic for all modes
[10:39 AM] (Channel) MdB: Has to simply give up on the limit if the vehicle is reasonably close to the target alt…
[10:40 AM] (Channel) LV: for a corner case, without data, are we changing behaviour ?
[10:40 AM] (Channel) Naterater.mobile: But if you’re on a legal altitude ceiling, that may be bad.
- [10:41 AM] (Channel) LV: that has been in use for years
[10:41 AM] (Channel) Naterater.mobile: There’s data in the discuss forum post linked in the comments.
UTC0040 - GSoC Balance Bot ready-to-merge
UTC0042 - GSoC funding request
UTC0043 - Copter update
- Not much to update people on since last week
- 3.6 our door soon
- Rc3 out soon
- Critical fixes from tridge
- Rebase?
- Or cherry-pick in?
- Might rebase then remove problematic patches
UTC0045 - Rover update
- Rc1 is still out there
- Lane-based controller slowing down for corners etc
- Doesn’t slow down as much in some situations
- Old code would make it slow down more in some situations
- Problem for very slow vehicles
- Has been working with Leonard on ideas for future cornering algorithms
UTC0047 - Plane update
- Plane will be rebased for the beta
UTC0047 - build system changes
- Trying to make build system a lot faster
- Dependency stuff has changed so if you see something odd please report it!
- [10:50 AM] (Channel) tridge: http://firmware.ardupilot.org/Copter/latest/sparky2/
- Our own bootloader is ready
- Bootloaders built and in our tree under Tools
- https://github.com/ArduPilot/ardupilot/tree/master/Tools/bootloaders
- .hex-with-bl
- Betaflight / inav / cleanflight tools can flash with their own tools using DFU
- Much more accessible for betaflight etc users!
- Try AP by clicking on existing tool and saying “load”
- With-bl initially (will wipe parameters not-in-fram)
- Without-bl usually (won’t wipe parameters)
- Uart-loading on multiple uarts
- Change baud-rate as part of upload supported
- PR for Wiki about how to create a bootloader using hwdef.dat
- Updating bootloader can be problematic for users who can’t use dfu
- CAN?
- Size constraints, but working on it
- Handy for upgrading peripherals
- Old bootloader was a pain for F7
- [10:53 AM] (Channel) Naterater.mobile: Can we now make ESC firmwares? Lol
- [10:53 AM] (Channel) JacobWalser: I’m working on some Nate
- [10:53 AM] To Weekly devcall: @Jacob: for stm32?
- [10:54 AM] (Channel) Naterater.mobile: I’m waiting for bi-directional BLHELI support through BL_heli (not just PWM)
- [10:54 AM] (Channel) Naterater.mobile: *Patiently waiting
- [10:55 AM] (Channel) JacobWalser: It should be there, we use it in all our vehicles
- [10:55 AM] (Channel) JacobWalser: not sure what you are asking for
- [10:55 AM] (Channel) JacobWalser: @peter yes stm32
- [10:56 AM] (Channel) Naterater.mobile: https://github.com/ArduPilot/ardupilot/issues/8579
- [10:56 AM] To Weekly devcall: @Jacob So a replacement for the closed-source?
- [10:56 AM] (Channel) JacobWalser: yes sir
- [10:56 AM] To Weekly devcall: Sweet. Do you have a workflow for developing it?
- [10:57 AM] (Channel) JacobWalser: Yes, I’ve got some hardware hacked wired up and ready to go
- [10:57 AM] To Weekly devcall: Nice!
- [10:58 AM] (Channel) JacobWalser: https://photos.app.goo.gl/etERkEoBFDQdvWDg8
- SD-card-based-updated in the future
- USB would probably be more convenient anyway
- Fmuv2 v3 and are all done, too
- Mavlink command for updating bootloader?
- [11:04 AM] (Channel) FF: +1 for a MAVLink command!
- Hard to recover a PixHawk2 - really need a JTAG adaptor
- Tridge has been working with David Sidrane on board IDs
UTC0107 - marketing committee vote
