Dev call June 10, 2024
Issues & Pull Requests
Copter & Rover
Plane
Attendee count (max): 14
UTC2301 - fix generation of compile_commands.json file by bugobliterator · Pull Request #18 · ArduPilot/waf · GitHub
Closed and replaced with a different PR
UTC 2302 - Use in_rc_failsafe method in arming by peterbarker · Pull Request #18358 · ArduPilot/ardupilot · GitHub
Needs some more testing,work
Comments in PR
UTC 2305 AP_HAL_ChibiOS: Update readme for RADIX2HD by mluessi · Pull Request #24724 · ArduPilot/ardupilot · GitHub
Merged
UTC 2311 AP_ADSB: cache course-over-ground for GPS message by peterbarker · Pull Request #25985 · ArduPilot/ardupilot · GitHub
Merge on CI Pass
UTC 2314 Copter: Change the sub-mode description(NFC) by muramura · Pull Request #26910 · ArduPilot/ardupilot · GitHub
Leonard approved
Merged
UTC 2315 Rover: Use common variables by muramura · Pull Request #26964 · ArduPilot/ardupilot · GitHub
Merged
UTC 2317 Copter: Enable processing by muramura · Pull Request #27134 · ArduPilot/ardupilot · GitHub
Merged
UTC 2319 GCS_MAVLink: Add support for parity to Serial passthrough by brad112358 · Pull Request #27152 · ArduPilot/ardupilot · GitHub
Merged
UTC 2325 Plane Update
Need an 4.5.4 release because on an IMU issue with Pixhawk 6X not being able to ARM
UTC 2328 SITL: make simulated SBP2 vastly more accurate by peterbarker · Pull Request #27230 · ArduPilot/ardupilot · GitHub
Merged
UTC 2330 AP_BattMonitor: prevent memory corruption when manipulating DroneCAN backends by peterbarker · Pull Request #27233 · ArduPilot/ardupilot · GitHub
Merged
UTC 2303 Correct board reservations by peterbarker · Pull Request #27238 · ArduPilot/ardupilot · GitHub
Merged
UTC 2335 Plane: Merge ArduPlane.cpp and Plane.cpp by peterbarker · Pull Request #27239 · ArduPilot/ardupilot · GitHub
Delay merge
UTC 2326 Copter: tidy failsafe action handling by peterbarker · Pull Request #27240 · ArduPilot/ardupilot · GitHub
Needs testing
UTC 23378 GCS_MAVLink: remove MOUNT_CONFIGURE/MOUNT_CONTROL handling by default by peterbarker · Pull Request #27245 · ArduPilot/ardupilot · GitHub
Merged
UTC 2338 AP_NavEKF: tidy creation of vectors by peterbarker · Pull Request #27241 · ArduPilot/ardupilot · GitHub
Merged
UTC 2339 AC_Fence: warn on use of old fence point / rally point protocols by peterbarker · Pull Request #27246 · ArduPilot/ardupilot · GitHub
Merged
UTC 2340 AP_Follow: clarify what we're doing when rotating a vector by peterbarker · Pull Request #27247 · ArduPilot/ardupilot · GitHub
Merged
UTC 2341 AP_Baro: Add in BMP581 Driver by cuav-chen2 · Pull Request #27249 · ArduPilot/ardupilot · GitHub
Merged
UTC 2344 AP_Common: rearrange get_vector_from_origin_NEU to be less destructive by peterbarker · Pull Request #27253 · ArduPilot/ardupilot · GitHub
Merged
UTC 2347 Tidy AP_Follow library by peterbarker · Pull Request #27254 · ArduPilot/ardupilot · GitHub
Delay merge
UTC 2350 AP_Common: Location: allow retrieval of Vector3p from vector-from-origin by peterbarker · Pull Request #27256 · ArduPilot/ardupilot · GitHub
Merge on CI Pass
UTC 2352 AP_AHRS: clarify frame of get_location_from_origin_offset by peterbarker · Pull Request #27259 · ArduPilot/ardupilot · GitHub
Merge on CI Pass
UTC 2354 SITL: add simulated tie-down clamp by peterbarker · Pull Request #27272 · ArduPilot/ardupilot · GitHub
Merged
2357 UTC Plane: Stage servo wiggles one after another by ohitstarik · Pull Request #27275 · ArduPilot/ardupilot · GitHub
Merge after autotest fixed
2359 When will we move to 4.6.0?
Aiming to be in beta before the Conference
