Dev Call Jan 6, 2020 2300 UTC
Issues & Pull Requests
**FPort Testing
** Hott Telem
Plane
Copter
Rover
Attendee count (max): 19
UTC1103 - Sid and compasses
  • https://github.com/ArduPilot/ardupilot/pull/12629
  • SITL testing found a few things, fixed
  • Some interesting compile-time checks
  • Typesafe indexes
    • Uses a class to add type-safety for indexing
    • Some accessibility issues on members
  • Randy to review
  • This is a major change in the way we do compasses
  • SITL now allows you to specify types so you can test behaviour
  • Currently If you boot up and your last compass is missing then we allow you to fly.
    • If you are missing your second-last we allow you to fly
    • This is fixed in this PR
  • MissionPlanner UI will need updates
    • It’s in the beta
UTC1111 - convert servo function to AP16
UTC1123 - https://github.com/ArduPilot/ardupilot/pull/13172
  • Reversing the option
  • Two problems
    • Transmitters are hard to program?
    • Spektrum transmitters can have dedicated functions on switches
  • Entirely fresh storage would fix it
  • RC_OPTIONS could enable reverse
    • Tiny bit of code to enable reversing
  • RC_OPTIONS also has a bit to allow fport
    • Changes behaviour of half-duplex
    • Pad bye when switching from receive to transmit
    • Bug in fport firmware where it reads 16-bits at a time
    • The option adds a pad byte
    • S-port seems to do the same thing
UTC1131 - https://github.com/ArduPilot/ardupilot/pull/13159
  • Copter frames as tailsitters
  • Defaults to motor matrix
  • Doesn’t change standard multicopter use case
  • No parameter changes for existing tailsitter users
  • Octo tailsitter coming up
    • Video or it didn’t happen
  • merged!
UTC1138 - https://github.com/ArduPilot/ardupilot/pull/13156/files
  • Merged!
  • Initialisation calls missed
UTC1141 - https://github.com/ArduPilot/ardupilot/pull/13152
  • Is creating a new fence overkill?
  • distance from fence instead?
  • How-far-outside-fence
  • Should check for breach on the polygons
  • Needs some testing in autotest
  • Rishab
UTC0005 - tell all EKFs we’re taking off or touching down
UTC0006 - https://github.com/ArduPilot/ardupilot/pull/13118
  • move is_flying and flying_time into vehicle
  • [11:07 AM] (Channel) MdB: I was gonna offer to do it…
  • [11:07 AM] (Channel) MdB: If we liked it in the call :smiley:
  • AP_Stats could also handle it
    • But we could remove the state from AP_Stats instead!
  • [11:08 AM] (Channel) MdB: 4 less state variables? I’m in!
  • [11:09 AM] (Channel) MdB: I mean… :smiley:
  • Some discussions on reducing scripting resources
  • We will move the stuff into AP_Vehicle
  • Change the airspeed function to take a reference rather than a pointer
UTC0018 - compiling out navekf2 etc
UTC0031 - https://github.com/ArduPilot/ardupilot/pull/12829
  • Merged!
  • Circle-mode control thingies
  • Backporting to 4.0.2, perhaps
UTC0032 - https://github.com/ArduPilot/ardupilot/pull/8307
  • Loading old parameters leads to new stick in input
  • Tridge: will cause users pain
    • Randy: will quickly be easier for users
    • [11:39 AM] (Channel) Naterater.mobile:
    • This has been a problem for ages… the only time we get a clean set of parameters are if we have them loaded prior to updating firmware.
  • Nate: RC2_OPTION and RCMAP_PITCH were both set and this was bad
    • Double-map issues
    • Limited number of inputs and limited number of outputs
  • Consistent with servo library
  • Heli-quadplane
    • Rcmap collective
    • Sometimes same as throttle sometimes not
  • Rudder-only with undercarriage
  • Some discussions on nomenclature for rudder-only planes
  • Rudder-only IOMCU needs checking
  • Make sure loading old parameters is as nice as possible
  • Ask GCS authors when loading onto a vehicle that doesn’t use RCMAP whether it should blat the RC options
  • @Volatile and @Calibration for parameters would be nice
UTC0100 - https://github.com/ArduPilot/ardupilot/issues/1254
  • Closed
  • Not enough appetite for this one
UTC0101 - https://github.com/ArduPilot/ardupilot/pull/13176
  • Make this a script?
  • [12:04 PM] (Channel) MdB: oh I thought this was all new code :smiley:
  • [12:04 PM] (Channel) MdB: Makes sense
  • We’lll make this a script
UTC0109 - FPORT and Hott Telemetry
  • Backport FPort to 4.0?
  • Hott still being tested
  • Graupner will be testing it
  • Creation of an AP_Telem
    • To hold all the little RC protocols initially
UTC0123 - Plane 4.0 release
  • Going well so far
  • Wrong clock on Durandal port
  • Orange had incorrect clock on i2c2
  • Pitch7 is close to being level
    • Auto-rotation-detection can’t distinguish between the two
    • So will fail sometimes…
    • Should have said “no” to the pitch7 thing
    • New patch to exclude pitch-7 is in master
UTC0123 - https://github.com/ArduPilot/ardupilot/issues/12547
  • 4.0.1rc1 beta release in next day or two
  • Spektum 22ms is broken
    • Unsure if it a regression
    • Newer Spektrum receivers are sending different data!
  • Kakutef7-Mini watchdog reset
  • HMC compass not working?
  • Parameters getting wiped occasionally
  • Quiet buzzer issue
    • Andy Piper is working on it
  • Windows driver issue connecting CUAV board with MissionPlanner
    • Blue-screen
  • 3.6.9 crash / no logs / partner
    • Arming checks were zero
    • RF noise?
  • Release seems to have gone quite smoothly
UTC0136 - https://github.com/ArduPilot/ardupilot/issues/12509
  • Rover will get a 4.1 release in the next couple of weeks
  • Moving baseline support coming in
    • Merged
UTC0137 - constraining NAN internal error
  • Pos-rangefinder-height
  • Unhappy flow sensor?
UTC0142 - close
