Dev Call Jan 28 2019 2300 UTC
**Issues & Pull Requests **
Plane
Copter
Rover
AUVSI Booth Update
Attendee count (max): 24
UTC2302 - fix regression for tiltrotors
  • Spool-rate stuff broken tiltrotors
  • “What does zero PWM mean?”
    • No pulses
    • Safe state to command ESC with?
      • Yes
      • Some whinge
        • You can change that on some
  • Anything unsafe about sending min pwm?
    • Cutting pulses in the middle could be bad on NuttX
      • Could spin-up on blheli
      • Fixed under ChibiOS
  • Param was added to say “want no pulses”
    • Now being used across all motor types
    • This may have broken tailsitters
    • MdB: Q_M_SAFE_DISARM is the parameter
      • [10:06 AM] (Channel) Nate:
      • ARMING_REQUIRE is also the parameter.
  • Tiltrotors don’t spool up on master ATM
  • Regression
  • “When I’m disarmed I need there to be no pulses to my ESCs” is a safety thing
    • This PR would make that no longer happen
  • This PR does restore original behaviour
  • [10:07 AM] (Channel) MdB: This: https://github.com/ArduPilot/ardupilot/blob/master/libraries/AP_Motors/AP_MotorsMulticopter.cpp#L388 is what that’s trying to bypass
  • We should merge this then come back to do the no-pulses thing for tiltrotors
  • New function looks safe to be called from other vehicles but isn’t
    • Not used by multicopters/helicopters
  • ARMING_REQUIRE would seem to want to override both
    • But it also might not currently do so
  • Randy’s going to merge it!
UTC2310 - https://github.com/ArduPilot/ardupilot/pull/10351
  • Landing checks for relaxing position controllers were being bypassed
  • Can cause tip-overs
  • Also high-wind-days issues
  • Copy-and-paste from Copter
  • SITL says it’s fine
  • Mark and Pete - would appreciate testing of this!
  • Tridge and/or Leonard need to read through this before MdB is willing to fly it
  • Limited use for the function anyway
    • Throttle limiting
    • Shouldn’t be too dangerous
  • First time THR_MIX_MAN will be honoured on vehicle
UTC2311 - https://github.com/ArduPilot/ardupilot/pull/10265
  • Removed devcalltopic as we’ve determined we’ll change the meaning of the arming check bit
UTC2314 - https://github.com/ArduPilot/ardupilot/pull/10243
  • Looking for Chris! Are you there? Hello?
    • Present in Mumble not responding
  • Pretty close
UTC2316 - https://github.com/ArduPilot/ardupilot/pull/9240
  • Waiting for changes to the PR which tridge has requested
UTC2317 - https://github.com/ArduPilot/ardupilot/pull/8816
  • Rangefinder parameters
  • Randy checked the parameter upgrades were working
    • One parameter was being corrupted
    • A bit and back-and-forth
    • Still an issue with the upgrade code
    • Hopefully Dmitry will look at it and sort it out
UTC2319 - OBC branch
  • Whole bunch of avoidance code hard-coded to Plane
  • Peter will look at getting the mavlink stuff working according to spec
  • Once that’s working MO can get MP uploading
  • And Randy can get AC_Avoid stuff happening
  • Tom will look at getting auto-avoidance working for vehicles other than Plane
UTC2324 - Copter
  • MP is missing 3.6.3 and 3.6.4
    • MO is looking at it
    • Fixed in latest MP beta
  • Some user says Maytech 405 wing doesn’t boot with a compass attached
    • Works for Randy
      • mrobotics
    • Works for iampete
  • Parameters wiped when logs full
    • Probably new dataflash-block stuff
  • V2 vs v3 is causing issues
    • Taking features away later would suck
      • We should consider the savings “banked” for future core code changes rather than re-enabling features
    • Enhance MP to force v3 onto a v2 board, perhaps?
    • Randy would like to make v3 and v2 the same to reduce support
UTC2330 - Rover
  • 3.5 release beta testing
  • https://github.com/ArduPilot/ardupilot/issues/10350
  • Fewer testers for Rover, of course
  • Slower beta-testing
  • Two issues came up
    • Build server hasn’t rebuilt fmuv2 for -rc2
      • Fmuv3 definitely is up-to-date
      • Peter or Francisco can have a look
    • One-shot not working
      • Maybe the loop-rate?
      • Update frequency rate?
  • Need to improve the documentation
UTC2334 - AUVSI
  • 20x20 booth booked for 2019
  • Four companies in booth
    • BlueRobotics, Hex, SpectreWorx and Aion/Jeff’s Company
  • 30th April through to May 2nd
    • Conference starts on 29th
  • Booth number 4006
  • Some brainstorming to do
    • Open-source development track at the conference, perhaps
  • SRP will be there
  • Several other partners will also be there
    • No plans on pushing AP through partners (e.g. keychains)
      • JP: we have budget for it.
  • Might move earlier for 2020 to get a better floor space
  • May still have half the booth from last time
UTC2337 - testing of Plane Onion
  • Too cold for Nate to fly it
  • Tridge wants to test it before merging
UTC2341 - Unconference
JP: Dev Conference Agenda: if you are coming, and want a talking or demo slot, please add yourself. https://docs.google.com/spreadsheets/d/1cW35dP0-gOf8XrmqdhI5EZZ2i0CliJNX35D5n9yuAmI/edit#gid=0
  • MdB has been voluntold to do a scripting update
UTC2342 - scripting
  • Docs?
  • Probably not in Wiki for the time being
  • Maybe a README.md in the AP_Scripting folder
UTC2346 - GSoC
  • Ping Jaime if you want to mentor a GSoC student
